Google Links
» Log in
User Name:
Password:
Not a member yet?
Register Now!
Sponsors
Sponsors
Old 10-12-2006, 02:19 PM   #1 (permalink)
brentdog's Avatar
Photos: 0
brentdog is an unknown quantity at this point
Daytime running lights with automatic headlamp control
So I recently had the dealer turn on the daytime running lights feature on my 2004 330Ci (for safety and insurance discount). However, I'm seeing some odd behavior with respect to the automatic headlamp control, which I've always used. Normally, the automatic headlamp control turns on the headlamps in low light situations and turns them off in bright light situations. Since I've had the daytime running lights feature turned on, the lights are always on whenever the automatic headlamp control is used regardless of the ambient light level. These are the full headlamps, not the daytime lamps (high-beams at low voltage). The only way to actually get the daytime running lights to work is to turn the lights off (zero position on dash selector). I was expecting that with the daytime running lights and automatic headlamp control that during bright light, the daytime running lights would be on, and during low light, it would automatically switch to the regular lights (and vice versa). I'm addicted to the automatic headlamp control, so I really don't want to have to manually control the lights with the selector to get this to work properly.
Is the behavior I'm seeing correct? Can anyone confirm the proper inter-functionality of these 2 systems?
Thanks,
Brent
brentdog is offline   Reply With Quote
Old 10-13-2006, 03:07 PM   #2 (permalink)
Photos: 0
WestEast is an unknown quantity at this point
This is a coincidence. I was about to ask a similar question. I've always had this feature on, but never noticed what was going on during the day. It's worked fine at dusk/night. But these last months, with clear blue sky everyday, I noticed my lights were on. I eventually took it to the dealer, and under warranty, they replaced the sensor. That was last week. But I notice no change in behaviour. What I have noticed is that it does work (switch off)in certain daylight situations - and that is when the sky has cloud cover used: . Not sparse cloud, but a good 50%+ cover. When it clears, bam, the lights come ON again.
So in summary.
Lights ON - dusk, dark; and bright sun conditions.
Lights OFF - daylight with cloud.
Does this formula make sense......?? Or is the setup/sensor faulty.
WestEast is offline   Reply With Quote
Old 10-21-2008, 11:52 PM   #3 (permalink)
Photos: 0
afbluesuiter is on a distinguished road
I have the same problem in my 2003 530i. The lights are on during the day. But here is an added twist. With the headlight switch on automatic, the lights turn on, go through the auto levelling test and then the right headlight turns off and I get a "Check Low Beam" warning. But when I turn the lights on manually, the right headlight functions normally.
afbluesuiter is offline   Reply With Quote
Old 10-22-2008, 12:09 AM   #4 (permalink)
Photos: 0
witeshark is just really nicewiteshark is just really nicewiteshark is just really nicewiteshark is just really nice
Must be a problem in the sensor since manual control would most likely by pass that circuit section. To Brent's question, (post #1) - I think the DRL's are affecting the system voltage which in turns causes a sensor malfunction and by default, the system turns on full lights as a safety precaution.
vB code is On
Upgrade manual climate to automatic control ! BMW320TD 3-Series (E46, E90) 5 12-05-2004 02:41 AM
Daytime Running Lights. Graphic Designer Bimmer Talk/Motorsports Talk 7 07-16-2004 04:04 PM
question about the headlights wuballz 3-Series (E46, E90) 14 05-30-2004 08:39 PM
Daylight Running Lights for my 04 325? Graphic Designer 3-Series (E46, E90) 1 03-02-2004 10:34 AM
Daytime running lights off??? kbillan 3-Series (E46, E90) 4 11-24-2003 09:51 PM
SEO by vBSEO 3.1.0
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
