Dashboard Lights On E46 - What Is What? - BMW Forum - BimmerWerkz.com
Old 02-23-2005, 06:19 AM   #1 (permalink)
Ranz_Killa is an unknown quantity at this point
Thumbs up
Hi Guys.. 1stly im new to this forum..
so if this Q has been asked before, pls redirect me..
Basically, i am gettin all sorts of lights comin up on the dashboard, and hte problem is i cant find my manual.. so im not hundred 100% sure what is what.. ghead
Was wonderinf if there is a link, where it shows each icon from the dashboard and what it actually is..??
Cos so far i know iv got
- the engine management light on...
- the red airbag light...
- 2rdly which came up this morning, its a round yellow on, does NOT Say ABSin the middle, no exlamation mark, jst a yellow with round circle, i think its somethin to do with tyres or brakes???
Im more worried about the 3rd one..
all replies would definately be appreciated.. thanks guys./
Oh by the way, its a V Reg, E46, 318iSe.
Ranz_Killa is offline   Reply With Quote
Old 02-24-2005, 12:01 PM   #2 (permalink)
Sounds like the brake pad warning light to me
Old 02-24-2005, 04:54 PM   #3 (permalink)
clarkinc is an unknown quantity at this point
[snapback]297641[/snapback]
Sounds like the brakepad warning to me also (one yellow circle inside half parthesis)
clarkinc is offline   Reply With Quote
Old 02-24-2005, 05:20 PM   #4 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
I could be wrong, but it looks like you need a servicing. How many miles do you have on her? I would recommend that if you can't afford to bring the car to a mechanic, or if you prefer to do work on the car yourself, get a Peake Research Code reader, it'll read your OBC to find any error codes and tell you what they mean.
The "engine management light" I'm assuming that's comprable to the little symbol of an engine or "check engine" light or even "check engine soon" light. That could mean anything from an open gas tank to a bad cylinder firing. Using that tool could help you better identify what it is. There are also reset tools for the airbags, however, that really should be checked. Have you recently been in an accident or have just purchased her? Do you know if it's history if you got it used?
The last thing, I'm assuming, are your brake pads, they're low and have tripped the brake pad sensor. If that's the case, they're simple to change, just need a small jack and pretty much the tools that come with the car (basically speaking of course).
I'm sorry I cannot be of more help. I know how annoying those damn lights can be.
BTW,
Dough
ps... what's a V reg?
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 02-25-2005, 08:33 AM   #5 (permalink)
SimonH is an unknown quantity at this point
V reg refers to the year of registration in the UK. Each year uses the next letter of the alphabet. I don't know what year V represents (as I've been away from the UK for a while).
Simon
SimonH is offline   Reply With Quote
Old 03-01-2005, 09:32 AM   #6 (permalink)
chowip is an unknown quantity at this point
BTW,
Dough
[snapback]298642[/snapback]
chowip is offline   Reply With Quote
Old 03-01-2005, 09:36 AM   #7 (permalink)
Speaking of PEAK RESEARCH SCAN TOOL I have bought one to read the check engoine light on my 1999 E46 318SE ( from Uk), i got a fault code of AB and the table to read off is 61 but the fault code book does not have table 61! Can anyone tell me what the fault code AB represent for my BMW please?
regards,
chow
Old 03-01-2005, 09:42 AM   #8 (permalink)
Howie's Avatar
Howie is an unknown quantity at this point
I have had the air bag light problem before. It is activated under the seat by something attached to the seatbelt bit on the seat. I found that I used to keep a pouch with my CD's under my seat and must have knocked it a few times. Strangely it was on my previous E46 which was a V reg 318ise. )
The brake pad warning came on too, which is yellow circle with three blobs on each side. It just means they are low and will need replacing.
Howie is offline   Reply With Quote
Old 03-02-2005, 06:21 AM   #9 (permalink)
these dash lites are country specif (very different e.g. between canada and us cars).
if you log on to bwm owners circle, they hav pdfs of manuals. you can print and look...
Higher powered lights for E46 mnd 3-Series (E46, E90) 7 11-17-2005 12:19 PM
fuse for head lights on E46 sycow 3-Series (E46, E90) 2 10-07-2005 02:27 PM
wtb 99 e46 clear tail lights rdmethod Looking For 0 09-23-2005 12:50 AM
Dashboard Lights Not Working nmellor2004 5-Series (E12,E28, E34, E39, E60) 1 11-02-2004 08:44 PM
Dashboard Indicator Lights auburn330 3-Series (E46, E90) 1 09-26-2004 12:22 PM
