Cooling Problem - BMW Forum - BimmerWerkz.com
Old 12-01-2004, 08:48 AM   #1 (permalink)
bmw 318i se is an unknown quantity at this point
hi I have a problem with my cooling system the bottom pipe on the radiator never
gets hot just warm. could there be a air lock in the system. the heating system is fine blows out red hot. temp gauge sits in the middle any ideas many thanks.
bmw 318i se is offline   Reply With Quote
Old 12-02-2004, 12:53 PM   #2 (permalink)
white 330ci is an unknown quantity at this point
why is that a problem? used
are you talking about the tube that carries water out of the radiator?
white 330ci is offline   Reply With Quote
Old 12-04-2004, 12:31 PM   #3 (permalink)
sounds like you have no problem at all. the radiator return pipe shoudl be cooler.
watch the temp indicator closely though, they are buffered (i.e. the indicator sits right in the middle eventhough the sensor sees varying temperature. the needle starts going up only if it exceeds a certain value).
does the fan come on at all ?
528i Alarm Problem Xero 5-Series (E12,E28, E34, E39, E60) 5 01-03-2011 01:16 PM
Smg Problem On 330i johanfunsale 3-Series (E46, E90) 0 02-28-2005 07:33 AM
E34 Cooling System Problem 5_or_Better 5-Series (E12,E28, E34, E39, E60) 4 10-04-2004 08:36 AM
