Coolant Light and Level - BMW Forum - BimmerWerkz.com
post #1 of 18 (permalink) Old 10-16-2007, 08:17 PM Thread Starter
FrankieMyOne is an unknown quantity at this point
Started up my 2001 330CI leaving for work this morning and the coolant light came on but went off after about 10 seconds, never to come on again rest of the day or the return trip home. Engine always runs normal temp, no smells, etc. So just for grins I checked the coolant level after the car had been sitting all day and that red float was all the way down in the spout and the column looked bone dry. The car has 90k miles, and about 15k miles ago I had the water pump and belts all changed as well as the coolant changed out.
Any advice? Should I run to the dealer, or just top it off myself? I haven't noticed any leaks either.
Thanks!
FrankieMyOne is offline
post #2 of 18 (permalink) Old 10-16-2007, 08:27 PM
FL325i is an unknown quantity at this point
If it is gone, it is leaking. The dealer will just top it off and tell you it is normal to lose some, but you have a leak somewhere. I'd get it taken care of now.
FL325i is offline
post #3 of 18 (permalink) Old 10-16-2007, 08:30 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
my 740 il did this go around and check all the hoses and hose clamps one of mine was just lose (dont forget the heater core lines!)
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #4 of 18 (permalink) Old 10-16-2007, 08:32 PM Thread Starter
Okay, how soon do I need to get to the dealer? So if I don't see any coolant in the spout there, does that mean I'm really low like no coolant in the tank? Or am I okay to drive a few days?
post #5 of 18 (permalink) Old 10-16-2007, 08:34 PM Thread Starter
So if I have a leak will I see puddles on the ground? Or does it only leak going down the road when the engine is running hard?
post #6 of 18 (permalink) Old 10-16-2007, 08:38 PM
mine leaked only after it was parked. but my friend 330 leaked only when he was driveing just keep filling the coolant chamber till you can get it there. i had to fill mine daily for 2 week till i figured it out.
post #7 of 18 (permalink) Old 10-16-2007, 08:58 PM Thread Starter
What kind of coolant should I buy from say the AutoZone?
post #8 of 18 (permalink) Old 10-16-2007, 09:05 PM
You should get the proper coolant from BMW or get it online. You can use distilled water for small top offs.
Small leaks can be hard to detect, especially if they find there way to a hot part of the engine or tranny and evaporate quickly.
FL325i is offline
post #9 of 18 (permalink) Old 10-16-2007, 09:10 PM
FL325i is offline
post #10 of 18 (permalink) Old 10-16-2007, 09:36 PM
i advise you NOT to every order anything from them ever i have had bad experiances with getting bmw parts from them. i Am currently waiting for a $500 return from them.
post #11 of 18 (permalink) Old 10-16-2007, 09:43 PM Thread Starter
Is there a brand I can buy from Pepboys or AutoZone?
post #12 of 18 (permalink) Old 10-16-2007, 10:04 PM
Good to know. I just did a quick search for a picture. Where do you get your coolant? I'll be doing a flush soon. Ironically, my wife took the car down to the dealer several thousand ago to tell them the coolant level was low, and they just filled the reservoir. I know I have something going on there, too.
FL325i is offline
post #13 of 18 (permalink) Old 10-17-2007, 07:16 AM
Mr. Bacon
dannyb's Avatar
dannyb is a glorious beacon of light dannyb is a glorious beacon of light dannyb is a glorious beacon of light dannyb is a glorious beacon of light dannyb is a glorious beacon of light dannyb is a glorious beacon of light
Send a message via MSN to dannyb
My cap was too loose and the coolant was coming out, you might want to check that.
that's my whore ; )
dannyb is offline
post #14 of 18 (permalink) Old 10-17-2007, 10:10 PM Thread Starter
I went ahead and followed the advice on some other threads about topping off the coolant with some distilled water. It took about 2 and 1/2 cups (1 cup being 8 fl. oz.) to get it back to max. Do you guys think I'll be okay with that solution? I'll be sure to check the coolant level over the next week to see if I'm down any.
Cheers!
post #15 of 18 (permalink) Old 10-17-2007, 10:47 PM
you can just but a couple gallons from the dealer
or get Coolant that is phosphate and selicate free such as ZEREX G48 or ZEREX G05.
Cooland Level light on my 525i!!! jnstrcklnd 5-Series (E12,E28, E34, E39, E60) 8 10-06-2006 06:04 PM
Check Coolant Level light .... lieshers 3-Series (E36) 3 09-06-2004 10:52 PM
COOLANT LIGHT shield 3-Series (E21, E30) 2 08-31-2004 12:16 PM
check coolant level message retomul 3-Series (E36) 4 07-24-2004 01:32 PM
