coolant leak - BMW Forum - BimmerWerkz.com
Old 09-07-2004, 11:38 PM   #1 (permalink)
white 330ci is an unknown quantity at this point
i have a small coolant leak coming from the bleeder valve right next to the fill cap.
i have tried tightening the cap but that didn't help used
any ideas?
i will check the o-ring tommorow, when it has cooled down
white 330ci is offline   Reply With Quote
Old 09-08-2004, 05:31 PM   #2 (permalink)
moto is an unknown quantity at this point
White 330 ci. I don't think it's a major problem.
I remember watching the technition bleeding the
cooling system of my 2000 328i when I had the
coolant changed in June. The screw seemed to
have a spring around it and it probably has some
sort of seal which dried out or split. I'd take it to
the dealer first and ask how to remove it.
MOTO
moto is offline   Reply With Quote
Old 09-08-2004, 06:39 PM   #3 (permalink)
ya i will tried putting oil around the seal but have not had time to test it, if that doesn't work i will just replace the cap.
97 540ia, Coolant leak, but cant find the source! ///Matt 5-Series (E12,E28, E34, E39, E60) 7 11-08-2005 11:25 AM
1997 328i Coolant Leak and Maintenance Larry Horne 3-Series (E36) 4 10-15-2005 07:45 PM
Coolant Leak From Sensor? BMW-ATI 3-Series (E36) 7 06-23-2005 07:41 AM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
Problem with the Coolant Leak RedBeemer95 3-Series (E36) 3 07-23-2004 02:53 PM
