Coolant - BMW Forum - BimmerWerkz.com
Old 12-03-2003, 08:11 AM   #1 (permalink)
kkevin77 is an unknown quantity at this point
Recently my coolant light comes on and then turns off after a few minutes. Does this sound like a electric malfunction or does it mean that i have to add more coolant? Not sure if i'm low or not. LIght came on this morning and then off a few minutes thereafter. Thx
kkevin77 is offline   Reply With Quote
Old 12-03-2003, 08:15 AM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Add coolant.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 12-03-2003, 11:25 AM   #3 (permalink)
blackbmw330 is an unknown quantity at this point
This happen to me before and I called the dealer and he told me that adding water was sufficient....
blackbmw330 is offline   Reply With Quote
Old 12-03-2003, 11:32 AM   #4 (permalink)
Yes, you can add water. But don't make a habit of it because you'll end up thinning out the mixture which could, over time, cause the radiator to rot and leak. Prestone has 50/50 mix of coolant and water (distilled) called Quick Fill. Runs like 5$ US a bottle (or so). Get that, top off your coolant, put the bottle in your trunk and use it when/if needed.
Old 12-03-2003, 12:15 PM   #5 (permalink)
AZ325Ci is on a distinguished road
this is becoming a common problem with newer bmw's. just add a little bit of distilled water (recommend no more than 2 cups) or get one of those coolant/water mixer as greendragon has mentioned.
i've had to do this once to mine just a couple of months ago and so far that was the only time.
AZ325Ci is offline   Reply With Quote
Old 12-03-2003, 12:57 PM   #6 (permalink)
Same here, and mines an e36.
Old 12-03-2003, 11:35 PM   #7 (permalink)
Thanks guys,
Does anyone know if Advance Auto Parts has the 50/50 coolant mixture?
Old 12-04-2003, 12:02 AM   #8 (permalink)
Yes they do
Old 12-04-2003, 12:03 AM   #9 (permalink)
Thanks!
Old 12-04-2003, 12:08 AM   #10 (permalink)
Old 12-05-2003, 12:33 AM   #11 (permalink)
careful with those mixtures. i'd buy the antifreeze form the dealer and mix 50:50 yourself with distilled h20. i do not trust aftermarket antifreeze (different ph, differnet anitcorrosion chemistries, you can screw up an alloy head and collant seals).
peter
Old 12-05-2003, 01:21 AM   #12 (permalink)
KingScare's Avatar
Car: 98 M3
KingScare is an unknown quantity at this point
Send a message via MSN to KingScare
I just use prestone...the greeen stuff!!!!
Looks so refreshing!!!
KingScare is offline   Reply With Quote
How To Replace Coolant? tomsbmw325is 3-Series (E21, E30) 2 05-31-2005 03:53 PM
Just Used Tesco Ready Mix Coolant. Is That Wrong? resus 3-Series (E46, E90) 1 04-03-2005 08:15 PM
Leaking Coolant uclabruins1996 3-Series (E36) 13 10-30-2004 09:01 PM
coolant dropping -- due to broken cap RedBeemer95 3-Series (E36) 3 09-12-2004 09:48 AM
E39 coolant level sensor NC540i 5-Series (E12,E28, E34, E39, E60) 4 05-27-2004 12:56 PM
