Control arms - BMW Forum - BimmerWerkz.com
post #1 of 19 (permalink) Old 03-01-2004, 10:11 AM Thread Starter
RobyCi is an unknown quantity at this point
Someone has had some problems about E46 front control arm?
Thanks
<img src='http://carandfish.altervista.org/signTech.jpg' border='0' alt='user posted image' />
I write from Italy. My English is not very well.
RobyCi is offline
post #2 of 19 (permalink) Old 03-01-2004, 11:52 AM
Groucho's Avatar
Groucho is an unknown quantity at this point
Thanks
No problems per se, though my control arm bushing had finally worn out at 95k miles in my '99 323i Sport 5-spd. The stock rubber bushings have been known to wear in as little as 30k miles(I bought my whip at 54k miles last year, so they were probably changed before) , so I replaced them with polyurethane bushings from Bimmerworld. Much tighter steering now, at the expense of slightly hight road noise (nothing too major, though). Very, very nice...I highly recommend them.
<img src='http://home.bak.rr.com/bimmerbob/images/SIGNATURECSIM.jpg' border='0' alt='user posted image' />
Groucho is offline
post #3 of 19 (permalink) Old 03-01-2004, 04:33 PM
my dad just had his control arms and CA bushings replaced at 19k miles in his 2002 330ci. he bought it at 9k miles and the dealer said the front took a huge shock from the previous owner but no body work had been done, so that's probably why they went so early
MrM3 is offline
post #4 of 19 (permalink) Old 03-02-2004, 03:54 AM Thread Starter
I have install PowerFlex bushes like Groucho.
I have open a thread in this link for this product:
http://www.bmw-forums.com/forum/inde...showtopic=9196.
E46 3 Series has many problems about control arms and bushes.
If you see the 99-01 version and 01 to current version these are the mods:
- bushes from 60 to 66mm;
- new control arms, new design;
- new design reinforce;
- new antiroll bar;
Bwm Has applied this mod to resolve that problem but me and others
to resolve the problem must replace all for 650$!!!!!!!
Sorry if my english is not correct.
RobyCi is offline
post #5 of 19 (permalink) Old 03-02-2004, 02:02 PM
otamara67 is an unknown quantity at this point
I have a 2000 323i and have had my brakes and rotors replaced and my steering wheel still shakes when trying to brake at high speeds. I have tried explaining this to several people and they still keep telling me it's my rotors. So now I finally have a clue as to what it could be after looking here. What exactly are the contol arms and bushes? I told the serviceman at BMW about this and he also mention some rubber part might need to be replaced because it could be worn, is this the bushes? ghead
otamara67 is offline
post #6 of 19 (permalink) Old 03-04-2004, 03:36 AM Thread Starter
For otamara67:
This is a pic of my car with PowerFlex bushes:
Control arms are the components with boomerang design.
The blue round component is one of two bushes.
You can see the control arm is fixed in.
If your steering wheel still shakes when trying to brake at high speeds,
probably you must replace bushes. Try PowerFlex bushes.
PowerFlex bushes uses the huretane material that is very hard.
Originale bushes uses a very soft rubber.
Check also control arms!!!!
Frequently must be replaced.
See this link:
http://www.bimmerworld.com
RobyCi is offline
post #7 of 19 (permalink) Old 03-05-2004, 10:47 AM
ss3964spd is an unknown quantity at this point
I can understand why the bushings may need to be replaced, but why would the control arms need replacing?
Dan
ss3964spd is offline
post #8 of 19 (permalink) Old 03-05-2004, 10:59 AM Thread Starter
Control arm has been fixed in three points.
The first ones is the bush, the others are rubber component.
When Bush fails, rubber component has an incorrect movement and fails.
Rubber component has been fixed directly in control arm and can't replace it!
You must replace the control arm.
RobyCi is offline
post #9 of 19 (permalink) Old 03-05-2004, 03:47 PM
Dan
actually the control arms usually dont need to be replaced, the ball joints do. if all 4 ball joints were shot, at around $40 a piece it would cost almost as much as just buying a new control arm (about $90 a piece)
MrM3 is offline
post #10 of 19 (permalink) Old 03-05-2004, 04:04 PM
Mach 5's Avatar
Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute Mach 5 has a reputation beyond repute
I have not found a place that sells the ball joints without the control arm. I have a bad outer ball joint now and would like to replace just the joint if I can. If you know of a place that sells the ball joint only for an e46 please let me know. Currently control arms for the e46 run about $110 each.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline
post #11 of 19 (permalink) Old 03-05-2004, 07:04 PM
Ben
here's a link for $48 e46 ball joints http://catalog.alloembmwparts.com/?year=20...h_button23.y=11
MrM3 is offline
post #12 of 19 (permalink) Old 03-08-2004, 03:39 AM Thread Starter
Central ball joint can't be replaced.
It has been fixed in control arm
RobyCi is offline
post #13 of 19 (permalink) Old 03-08-2004, 11:47 AM
Beantown330i is an unknown quantity at this point
If the car is still under warranty, will the dealer replace the control arm under warranty?
Beantown330i is offline
post #14 of 19 (permalink) Old 03-08-2004, 02:28 PM
yes, unless they can prove that it was damaged from a pothole, curb, or anything that would be your fault
MrM3 is offline
post #15 of 19 (permalink) Old 03-08-2004, 04:58 PM
Mach 5's Avatar
Thanks for the link. But the only ball joint listed for a 2000 328ci is for the rear control arm to wishbone upper. I need the outer ball joint on the right front control arm.
Ben
Mach 5 is offline
Need to replace my Front Control Arms pamato 5-Series (E12,E28, E34, E39, E60) 10 11-01-2005 04:17 PM
Do My Control Arms Need To Be Replaced? 2000BMW323i 3-Series (E46, E90) 0 07-17-2005 03:09 AM
'97 740il Control Arms Golden1 1,6,7,8 - Series and Mini Cooper 1 11-09-2004 10:11 PM
Control Arms, Bushings, or both? clmautz 3-Series (E46, E90) 3 07-08-2004 12:28 PM
Control arms broken ghettozn 3-Series (E36) 5 06-10-2004 10:41 PM
