Computer Malfunction? Help? - BMW Forum - BimmerWerkz.com
Old 06-30-2004, 09:58 AM   #1 (permalink)
EnvyM3's Avatar
EnvyM3 is an unknown quantity at this point
Send a message via Yahoo to EnvyM3
Just bought a 2000 323ci two months ago and I need advice? The outside tempurature gague is stuck at -40 degrees. Sometimes while i'm driving, the computer will beep and then the -40 will be flashing on the computer. Any idea why? Also, the storage compartment over the ashtray is open and will not click to stay closed...Any idea?
<img src='http://www.european-forums.com/forums/uploads/post-1-1119565837.jpg' border='0' alt='user posted image' />
EnvyM3 is offline   Reply With Quote
Old 06-30-2004, 10:36 AM   #2 (permalink)
E46Jim is an unknown quantity at this point
I'm pretty sure that when temp is below -38 the car normally beeps at startup to warn of cold temperatures and it automatically switches the heated rear screen on....maybe the beep is linked.
E46Jim is offline   Reply With Quote
Old 06-30-2004, 11:11 AM   #3 (permalink)
Relevart's Avatar
Relevart is an unknown quantity at this point
When outside temp drops to 3 deg C (37 deg F) or below OBC autmatically displays outside temperature, regardless of what you set it to or what it was set last time and car beeps.
The reason for that to warn driver that outside temperature dropped to the point, that ice can forme on the road surface at certain atmosferic conditions, like bridges, open roads with strong wind, etc....
The fact that outside temperature displayed is -40 deg C (or F) most likely means of a damaged sensor(s) behind splash guard in wheel well. Unless it is really that cold in June, where you live...
It is probable, that your're having problem with your AC, I think outside temp is factored in the logic of AC.
Relevart is offline   Reply With Quote
Old 06-30-2004, 12:12 PM   #4 (permalink)
pmolfese is an unknown quantity at this point
I had an outside temperature gauge go out on a 94 Dodge Caravan. Didn't seem like it was that expensive to replace, just a thought.
<img src='http://homepage.mac.com/pmolfese/images/IMG_0145.jpg' border='0' alt='user posted image' />
pmolfese is offline   Reply With Quote
Old 06-30-2004, 12:28 PM   #5 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
If it is reading -40 degrees all the time the outside temp sensor is most likely toast. It is behind a splash guard on the drivers side, if i remember right. It can sometimes get ripped off in a bad pothole or it may just have gone out. The part is not that expensive and easily replaced.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline   Reply With Quote
Old 06-30-2004, 02:01 PM   #6 (permalink)
EnvyM3's Avatar
Anyone know if the outside temp sensor is covered by manufacturers warranty?
Old 06-30-2004, 02:39 PM   #7 (permalink)
Mach 5's Avatar
If it is faulty it should be covered by the 4yr/50K mile warranty, if it is missing you will most likely have to pay.
Ben
Old 06-30-2004, 05:06 PM   #8 (permalink)
remote chance: wire unhooked. it would show minimum temp as it sees no res. mach5: am i smoking crack on this one?
peter
Old 07-01-2004, 04:21 PM   #9 (permalink)
Mach 5's Avatar
peter
No you are not smoking crack. The wire could be unhooked and you would get the min. reading on -40. It is however unlikely that the wire would fall off.
Ben
On Board computer dmonk 3-Series (E36) 9 08-29-2010 09:03 PM
can i retrofit 13 button onboard computer onto my car? träumer 3-Series (E21, E30) 4 11-01-2005 07:37 PM
Turning Computer (or Temp Display) On? Superfry 3-Series (E46, E90) 1 01-11-2005 12:30 PM
X5: 0-60 in 4.0 tcpgv 1,6,7,8 - Series and Mini Cooper 6 03-30-2004 02:51 AM
Trip computer not working in 88 735i ericesquire 1,6,7,8 - Series and Mini Cooper 0 12-10-2003 06:24 AM
