Cold start noise - BMW Forum - BimmerWerkz.com
Old 09-30-2003, 11:42 PM   #1 (permalink)
moto is an unknown quantity at this point
Hello bimmer fans. My 2000 328i makes a
sqeaky noise which lasts for only a few seconds when
the car sits for more than three days. If I start it the
next day, it is fine. It sounds like a pully/belt noise.
Also, I plan on putting the car away for the winter
next month. Is there any special things I should do?
I plan on adding a fuel stabilizer in the gas tank. I
will probably start it once in a while to.
moto is offline   Reply With Quote
Old 10-01-2003, 12:30 PM   #2 (permalink)
L337E46's Avatar
L337E46 will become famous soon enoughL337E46 will become famous soon enough
highly likely a bad pulley.... causes the belt to go poo poo...
Pull out a stethascope and plant that thing next to the pulley you suspect, either that or pull out a foot long flathead screwdriver to see where the squeaking/screeching is coming from whilst you listen to the handle for funky noises. Obviously be careful where you put the stethascope or flathead..... Things can get messy inside the engine bay. I replaced a pulley around 75k along with a belt.
General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
L337E46 is offline   Reply With Quote
Beeping Noise On Every Start... Not Cold, Not Oil! zach 3-Series (E46, E90) 2 02-25-2005 02:15 PM
Cold Startup Rattling Noise victorgallas 3-Series (E36) 3 01-18-2005 11:27 AM
M50 Radling Noise At Cold Start BMW-Viking 3-Series (E36) 1 11-23-2004 04:56 AM
Growl/Gurgle Noise at Cold Start... HELP mathetas 3-Series (E36) 16 08-17-2004 09:12 AM
Cold Start Problem (fuel Pressure Drop) BEX 3-Series (E36) 6 05-16-2004 07:35 PM
