Cold air intake - BMW Forum - BimmerWerkz.com
Old 08-23-2004, 02:00 AM   #1 (permalink)
gman16 is an unknown quantity at this point
Hi guys,
I'm a newbie to this forum and am just beginning to mod the wifes '99 332I. I was told that a cold air intake should make a big difference in power. Is this true and also what brands would you guys recommend with the most bang for the buck? Also need to know if it will prevent me from clearing smog in Cali. I'll appreciate any input/advice you guys can offer. We have all the options except the power that I'm accustom to.
Thanks
gman16 is offline   Reply With Quote
Old 08-23-2004, 07:35 AM   #2 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
gman,
There are numerious types of intakes out there. Thier gains are different for each, but you won't get enourmous amounts of HP and torque out of them. Some say you'll only get about 10hp maybe just over 15hp for the 3 series BMW's, if you have an M3... a little more, a 5 series, even more.... though I am by no means an expert, but have read much about what others have said about intakes in this forum. Here are some intakes that I'm looking into:
Eurosport Evo II Carbon Fiber Conforti Intake System - E46 3 series.
GruppeM Ram Air Intake - E46 3 series
They range in price from a few hundered to just under a thousand dollars.
There are more out there....
But more gains will be attained with a combination of intake and a "chip", the most popular:
Conforti Performance Software and Shark Injector
That's about $350.
Exhust would help out too.
So to sum up, you'll get some better HP ratings (not ALOT) and also get a more aggressive sounding engine from the intake/exhust set up...
Hope this helps. I can't answer the California thing... not really from there...
Dough
PS: There are some sound clips available and reviews of intakes, do a search on the forum for GruppeM, and you'll find the clips.
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
Old 08-23-2004, 07:44 AM   #3 (permalink)
Saggis is an unknown quantity at this point
Send a message via ICQ to Saggis Send a message via MSN to Saggis
as above...
a good start is always a K&N filter...they do real good work but if your looking for the best go for a gruppe M, they are expensive but worth it from what ive heard...
i have a cone filter from K&N for about 80$ and i noticed a great difference in power...well okey not like a turbo or something but it was noticebl...
they also give your engine a better response time...which means when u push the pedal it will react quicker
Black E39 530i 2001 with full black leather interior and antracit roof.
Saggis is offline   Reply With Quote
Old 08-23-2004, 03:41 PM   #4 (permalink)
Aydin's Avatar
Aydin is an unknown quantity at this point
Are you guys kidding around. 10 hp from a intake??? I don't know about that. Can anyone verify????
I thought its more like 3-5
Aydin is offline   Reply With Quote
Old 08-23-2004, 04:12 PM   #5 (permalink)
doughboyea's Avatar
Aydin,
I could be wrong, of course, I am not an expert, nor am I a mechanic, I never claimed to be, however, when coupled with a "chip", gains are much greater than alone. An intake alone could produce the range in HP you mentioned, somewheres from 3 to 5 HP, however, when a Shark Injector is added, there's more HP taken from the advantage....
But of course, it would help if others verified this....
Dough
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Cold Air Intake Vs Ram Air Intake boeuf 5-Series (E12,E28, E34, E39, E60) 6 05-13-2005 08:25 PM
Cold Air Intake? KevinTS 3-Series (E36) 40 03-28-2005 02:17 PM
Cold Air Intake crisby_E30 3-Series (E21, E30) 6 10-12-2004 12:55 AM
2004 E60/530i Cold Air Intake - HELP howiedog 5-Series (E12,E28, E34, E39, E60) 2 07-13-2004 01:12 PM
