Code P1470 AND NONE OF THE DASHBOARD GUAGES WORK !! - BMW Forum - BimmerWerkz.com
Old 08-09-2009, 10:50 AM   #1 (permalink)
Car: 1999 323 i
Campbell 4220 is on a distinguished road
Hi,
I have a 1999 BMW 323 i :
I have check engine light on for code P1470.
Also, none of the 4 guages on the dashboard work...
These are 2 separate issues.
Help!
Campbell 4220 is offline   Reply With Quote
Old 08-09-2009, 11:40 AM   #2 (permalink)
About the gages, have you checked the fuse box?
Old 08-09-2009, 11:51 AM   #3 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
That code is :P1470 A/C Cycling Period Too Short
Which is to do with Air-con
As witeshark says chek your fuses.
If they are ok, disconnect the batt for 15 minutes, Neg 1st and reconnect Neg last, make sure you have the code for the radio if required.
Old 08-09-2009, 11:58 AM   #4 (permalink)
Car: 1999 323 i
Yes, the fuses are ok.
Now, what exactly will happen if I diconnect the batttery for 15 min?
Old 08-09-2009, 12:04 PM   #5 (permalink)
marti5's Avatar
It will reset all to basically factory settings so to speak.
Old 08-09-2009, 12:07 PM   #6 (permalink)
Car: 1999 323 i
I see.
Thanks!
Old 08-09-2009, 12:43 PM   #7 (permalink)
Car: 1999 323 i
By the way, for the gages, could it be that I need to change the instrument clusters on the dash board for the gages to work? I am not sure how costy that is..
Old 08-09-2009, 01:28 PM   #8 (permalink)
Car: 530i-2002 & E280-2007
rashid is on a distinguished road
check the connectors of the cluster .. there are two or three of them.
rashid is offline   Reply With Quote
Old 08-09-2009, 01:45 PM   #9 (permalink)
marti5's Avatar
Do the Batt re-set 1st see what happens...............
Old 08-09-2009, 02:37 PM   #10 (permalink)
Car: 1999 323 i
Will do!
fixing code P1470 liltex_mex 3-Series (E46, E90) 2 08-16-2009 12:57 AM
guages oilcan 5-Series (E12,E28, E34, E39, E60) 0 09-27-2007 12:03 PM
upgraded guages buuhh99 3-Series (E36) 30 05-14-2004 11:10 PM
325i to m3 guages? niki 3-Series (E36) 0 12-31-1969 07:00 PM
