Check engine light/misfire codes..HELP!!! - BMW Forum - BimmerWerkz.com
Old 08-28-2011, 01:25 PM   #1 (permalink)
Car: 2005 325 XI
Yeorgos is on a distinguished road
Hey guys I could really use some help here. I have a 2005 352XI with 140,000 miles. Within the lase three weeks have replaced the spark plugs; ignition coils, all four oxygen sensors. Yesterday I replaced the crankcase with all four hoses. I started it up and the "EML"; ABS and brake light. I drove the car and it was in limp mode. I checked again all the connnections. Nothing found no leaks, etc. Drove It in limp mode to Autozone and read codes. PO 300-306, which is misfires in cylinder 1-6, also PO 171 and PO 174, which is system tto lean bank 1 and bank 2. WTF!!! So I checked the spark plugs again and the tips are covered in black soot, they are not wet and no oil on them or on the coils. When I start the car up, the lil light that has the exclamation point doesn not come on, just the SES light, however, the car drives in limp mode. I press the accelerator and it barely goes. PLEASE HELP!!!!!
Yeorgos is offline   Reply With Quote
Old 08-29-2011, 07:34 AM   #2 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
I would try a "Reset" first, get a cheap code-reader too, this will save you labor charges !!
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Check Engine light and codes Onyx Dragon 3-Series (E36) 6 10-12-2010 02:22 PM
erroneous check engine light codes terrance141 1,6,7,8 - Series and Mini Cooper 3 04-03-2009 05:02 AM
E36 1998 3.18i random misfire, lose power check engine light cson 3-Series (E36) 30 06-11-2008 04:42 PM
540 Engine check light codes jraven2 5-Series (E12,E28, E34, E39, E60) 1 11-16-2006 02:41 AM
92 e36 fault codes? check engine light seven 3-Series (E36) 1 11-15-2006 03:50 PM
