Check engine light - BMW Forum - BimmerWerkz.com
post #1 of 12 (permalink) Old 11-29-2007, 01:33 PM Thread Starter
DCbmw2001 is on a distinguished road
Check engine light
I recently purchased a 2001 BMW 325i with 66K miles. The car runs great and everything seems to be fine. However, I noticed that the check engine light came on couple of times before an oil change. However, after an oil change, the check engine light came on more frequently and a whining sound coming from oil-filter housing when the engine is turned on (i.e. when the engine is cold). But the noise goes away, whereas the check engine light is persistent.
My mechanic has so far changed the vacuum hose and the spark plugs. The code of the "check engine light" is usually states Bank 1 and Bank 2 problem. I also took it to BMW dealership and the tech there suggested changing the "oil separator". Being frustrated with this, I want to know whether it sounds ok to change the oil separator or is it another hoax?
I appreciate your input. Thanks!
DCbmw2001 is offline
post #2 of 12 (permalink) Old 11-29-2007, 06:15 PM
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold AlpineSixAndSeven is a splendid one to behold
what OIL filter did you use... also ho long does it make the sound?
1992 318i Coupe parts car
I am Captain Obvious
AlpineSixAndSeven is offline
post #3 of 12 (permalink) Old 11-29-2007, 06:42 PM Thread Starter
I'm not sure about the oil filter, but the oil change was done by BMW dealership, so I think they used a proper filter. The sounds is about 10 minutes after starting from cold engine and once the engine is warmed up, the sound disappears...
post #4 of 12 (permalink) Old 11-29-2007, 06:57 PM
hmmm I was thinking that it is air in the oil filter housing or the improper Filter.........
post #5 of 12 (permalink) Old 11-29-2007, 09:55 PM
zibby's Avatar
Quoted: 1 Post(s)
There is no "check the engine" code bank 1 or bank 2.Bank 1 or 2 of what! ?
Find exactly what code your car is throwing out and post again.
As an example this could be "camshaft position sensor" bank 1 or 2.
Bank itself means nothing...
zibby is offline
post #6 of 12 (permalink) Old 11-30-2007, 02:48 AM
Moderator
Dirty_Tool's Avatar
Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute Dirty_Tool has a reputation beyond repute
oil separator is common problem and if you have it at dealer then im sure theyre qualified. Its probably a code for bank 1 and 2 too lean
DT
Dirty_Tool is offline
post #7 of 12 (permalink) Old 12-05-2007, 08:36 PM Thread Starter
correct, it's bank 1 and 2, engine too lean...
post #8 of 12 (permalink) Old 12-05-2007, 08:38 PM Thread Starter
thanks for your inputs...I'm taking the car to the dealer tomorrow...
post #9 of 12 (permalink) Old 12-05-2007, 08:40 PM
fuel delivery issue? clogged injector maybe? maybe run some seafoam in the gas when your low on gas...
post #10 of 12 (permalink) Old 12-08-2007, 01:13 PM Thread Starter
Just wanted to let you know that I had the "Oil Separator" replaced along with its vacuum hoses, and the car is back to normal with the "check engine" light off for the second day in a row...
post #11 of 12 (permalink) Old 12-08-2007, 06:31 PM
thats good!
post #12 of 12 (permalink) Old 12-10-2007, 04:09 AM
Moderator
Dirty_Tool's Avatar
hehe ... told ya :-)
DT
97" 540IA mystery with the check engine light ClaytonP 5-Series (E12,E28, E34, E39, E60) 3 10-21-2007 09:43 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 10:40 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 01:18 AM
Check Engine light went away Ferrahs 3-Series (E36) 14 07-17-2004 03:32 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 03:40 PM
