Check Eng Light Question - BMW Forum - BimmerWerkz.com
Old 11-01-2008, 09:10 PM   #1 (permalink)
opfor2's Avatar
Car: 2000 BMW 323i
opfor2 is on a distinguished road
Hi all,
Had the check Eng light come on on my 2000 323i today. Using the Peake R5/FCX-3 BMW code reader I got the following code Table 15, Code A8 = "Electrical thermostat mechanically jammed open" So does that mean that the coolant thermostat is jammed open? Where do I go from here?
Thanks
Dan..
opfor2 is offline   Reply With Quote
Old 11-01-2008, 10:18 PM   #2 (permalink)
zibby's Avatar
Car: yes
You need a new thermostat,because it went into fail/safe position(open).Not realy expensive thing to repair.
Z.
http://www.q8oils.it/
Old 11-04-2008, 08:31 PM   #3 (permalink)
TRuckee is an unknown quantity at this point
If you're a somewhat capable DIY'er you can probably DIY. All the parts you need to get to are right up front, but you should probably have the Benteley manual, or equivalent, for reference... and , of course the appropriate tools. The part is not expensive <aftermarket>, but getting all the air out of the cooling system after you do this easy swap wil take some time/effort. But it ain't a big deal; just takes some time.
What have you gotten for estimates for this repair from dealers or other service providers?
TRuckee is offline   Reply With Quote
Old 11-04-2008, 09:53 PM   #4 (permalink)
Steve323i99's Avatar
Car: 99 323i E46, 97 Jeep ZJ larado 5.2L
Steve323i99 is on a distinguished road
This is a relativly easy DIY. While your in there if these other items have not been replaced yet you may want to look at doing them too. Water Pump, Hoses, and the expansion tank. You can find the parts pretty cheap online from places like pelicanparts, bimmerzone and autohausaz.com. If you aren't a Do it yourselfer (DIY) then look into a reputable independant (INDY) shop.
UUC TSE3 | ST V1 coilovers | TMS sways | CSL replicas 18"x8.5" | ATE slotted rotors w/ Axxis USP | Clear lights all around
Steve323i99 is offline   Reply With Quote
318i check eng lite brdoggett 3-Series (E36) 0 09-06-2008 10:46 AM
Check Light And Check Engine Light 325is1994 3-Series (E36) 9 01-12-2005 01:36 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
Question about the check engine light. jdwango 3-Series (E36) 4 10-10-2003 10:51 AM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
