Car feels weaker Help! - BMW Forum - BimmerWerkz.com
Old 05-12-2011, 04:18 AM   #1 (permalink)
/Banned
huyatgr is on a distinguished road
I have a 2002 bmw 325i with 130k miles on it, ever since i got the car it had the check engine light on it, and it drove fine, now recently i feel like the car has lost power in first gear after that its fine, and the car is using up too much gas, the codes are
p0171
po174
p0313
p0444
since i dont have a smoke machine to test the vacuum leaks i decided to start with p0444 the purge valve went to the dealer and bought it and replaced the valve, and after replacing it i hear a ticking noise from the valve when i turn the ignition on, so i said let me try the old valve put it on and it did the same thing, and code still remains, now im stuck and have no clue of what to do, can someone please help i would really appreciate it.
huyatgr is offline   Reply With Quote
Old 05-12-2011, 09:10 PM   #2 (permalink)
looney1 is on a distinguished road
Hey i searched around the net for you and found these and hopefully they can help. Let me know if it helps.
OBD-II Trouble Code: P0171 System Too Lean (Bank 1)
P0174 = "System Too Lean (Bank 2)"
Possible solutions:
- Clean the MAF sensor
- Replaced any cracked MAF housing components
- Replace the "intake boot"
- Test ccv by plastic bagging oil-filler hole
- Replace the "ccv"
- Replace the fuel filter
- Replace the fuel pump
- Reseat the oil filler cap
SAE Code P0313
DTC Code 16697
Description Misfire Detected Low Fuel Level
P0444 is the Purge Valve or also called (breather valve), its located in the front part of the engine, right behind the Power steering fluid tank. Its attached to the engine. it has a sensor attached to it and two hoses. Only the dealer has the part, and the cost is $120, it took me about 15 min to replace.
Here are the steps i took.
THE CAR MUST BE OFF
1. Remove the air filter with the air ducts(will give you more room)
2. Remove the power steering tank(2 screws) and just move it to the side(no need to remove the hose)
3. Remove the Purge Valve, its attached to the engine (similar attachment as the muffler) has a rubber part which attache to the engine.
4. Remove the sensor
5. Remove the bigger(thicker) hose(you have to push in/pres on the safety pin) when locked it sticks out, to unlock you must push in.
6. Remove the smaller(thinner) hose(coming from engine) twist and pull(might take a while)
7. You are done removing.
Installing the new Purge valve is much faster, You may encounter problems installing the smaller(thiner) hose.(i just greesed the tip of the purge valve and it went in with no problems)
looney1 is offline   Reply With Quote
Old 05-12-2011, 09:18 PM   #3 (permalink)
Also try this link Solved - 2002 325i - 12 Error codes all at once
This guy had 12 codes come on at once and had most of your codes and it turned out to be the oil seperator
Old 05-13-2011, 11:40 AM   #4 (permalink)
KingZeus is on a distinguished road
Lol what the hell? thats my topic on other forums lool.
KingZeus is offline   Reply With Quote
Feels good... Linds 3-Series (E21, E30) 32 08-04-2009 04:01 PM
My M3 Feels Like A New Ride! FREDPLT M-Series (M1, M3, M5, M6) 5 04-30-2005 11:52 PM
E34 feels different Torque 5-Series (E12,E28, E34, E39, E60) 14 02-09-2004 05:30 PM
