can you help identify this strange rumbling/vibration? - BMW Forum - BimmerWerkz.com
Old 07-29-2012, 02:45 AM   #1 (permalink)
maxslomoff is an unknown quantity at this point
hey everyone,
i have a 2002 manual e46 325is with 90k and i am having a certain problem with it that is going to be hard to explain because its not exactly reproducible, and i know its going to be even harder to help understand it on a blog post...
the car has a rumble, or a stutter- a vibration that does not feel normal.
sometimes it feels like i'm driving over a thousand hoses.
when i cruise at low speed the ride is smooth. and when i gun it, sometimes it gets the rumble of a thousand hoses... this especially seems to happen if i accelerate in too low a gear. it seems to happen between 2500 and 3000 rpms... in a lower gear the vibration is way worse, but it seems to rumble even in 5th gear going 80 - its just much more subtle.
usually after the rumble happens i can smell a burning rubber smell when i get out of the car.
the problem seems to be getting worse, though i think its been going on for almost a year. i've only had the car for a year, but i don't remember if it was always there...
about two months ago i got the flex disk, drive belts, and the control arm bushings replaced...
a few weeks ago i got new tires and breaks at a different shop... they witnessed the rumbling but couldn't identify it.
when i first bought the car, there was a problem with the fuel mix, and the way the computer was telling it to inject fuel. i think it was a little too rich.
i'm going to try to replicate the rumble/vibration/stutter so i can video it and put it up here to better describe the problem.
in the meantime, if you guys have any ideas i'd like to look them over.
thanks a lot
max
maxslomoff is offline   Reply With Quote
Old 01-17-2013, 07:41 PM   #2 (permalink)
Durene's Avatar
Car: 2005 BMW 320i
Durene is on a distinguished road
I have had the same problem for a year....garage can not figure it out. Spend lots of money trying to fix the problem....
Did you find out what it was?
Durene is offline   Reply With Quote
Old 02-12-2013, 07:01 PM   #3 (permalink)
Zedfor's Avatar
Car: 2003 BMW Z4 3.0si, 2007 BMW X3 3.0
Zedfor is on a distinguished road
Check motor mounts first. If it is not the mm's it could be exhaust or any of the engine accessories; fan, power steering pump, etc. Any competent indy shop should be able it id the problem fairly quickly.
Sent from AutoGuide.com App
If you don't know where you are going, any road will get you there.
Editor - ZSCCA's CruiZin' NewZ
ZSCCA
Zedfor is offline   Reply With Quote
Strange occasional vibration at acceleration CrazyIsland 3-Series (E46, E90) 4 12-10-2009 02:00 PM
Strange random vibration at idle zabak80 3-Series (E36) 5 05-24-2009 03:19 PM
Rumbling Noise grant 5-Series (E12,E28, E34, E39, E60) 1 10-02-2004 10:05 AM
A/C Compressor Rumbling chris3 3-Series (E21, E30) 1 09-12-2004 12:35 PM
Tire rumbling MUD143 5-Series (E12,E28, E34, E39, E60) 5 01-06-2004 06:39 PM
