Can not read codes - BMW Forum - BimmerWerkz.com
Old 08-15-2009, 11:52 AM   #1 (permalink)
Car: 2001/325i CI SE /Convertible / Blue
enviropc is on a distinguished road
Can not read codes
Hi, ive just got my first E46 and his is my first post so Hi guys!!
The ABS light is onon my 1999 323i coupe and i have plugged in my ELM327 ver 1.2a lead using my laptop and can read various sensors using various bits of software but none of the software i have will let me read any fault codes or reset the oil service metre.
on the disc i have their was a folder called BMW that comtained a program called car scanner but this software does not connect to the car but other software will.
Basicaly my question is what software do you guys use on your USB OBD cables and is it available for free download anywhere?
Id like to be able to read and reset the fault codes and reset the oil service metre.
Thanks in advance.
justin
enviropc is offline   Reply With Quote
Old 08-16-2009, 12:38 AM   #2 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Cool
ELM327 software does not read ABS codes, Neither will it rest oil maintenance lights.
ELM327 and it's program software will read OBD2 engine codes only. They're working to expand the range but i don't think there is a ready proggie just yet.
oil reset: i have several past posts on how to do this. use the search function in the tabs above. type in oil reset and you should find the sequence with no probs :-)
Cheers
Old 08-16-2009, 12:37 PM   #3 (permalink)
thanks darkhorse.
Any recommendations on what equipment i can buy for my laptop that will let me do everything?
justin
Old 08-16-2009, 03:16 PM   #4 (permalink)
Red face
am looking at the same things. I will let you know what i find.
the program fron Palmer Engineering looks good. But yet again, still no ABS, SRS codes yet.
Quite frankly, an Actron, the kind that is about $150-250 might be a better deal right now. Some models can and will read engine, ABS, and SRS codes + engine data. Which model exactly, you need to research on that:-)
Cheers.
Old 08-17-2009, 05:01 PM   #5 (permalink)
Ok will have a look around.
if i find anything before you ill post here.
Fault codes read 99bmw528i 5-Series (E12,E28, E34, E39, E60) 6 12-08-2008 11:05 AM
BMW Carsoft 6.5 Diagnostic Interface Read/Reset/Erase codes Savage For Sale 6 05-16-2008 09:03 PM
Must Read Guys In Regard To Last Post About My Trans, Must Read pvalenti99 5-Series (E12,E28, E34, E39, E60) 3 04-08-2008 03:21 PM
Everyone Please Read! jllphan Bimmer Talk/Motorsports Talk 14 08-23-2004 05:08 PM
NEED your Help Read THIS! BmwRacing 3-Series (E36) 20 04-21-2004 10:30 AM
