Cam Position Sensor - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 09-22-2009, 03:00 PM Thread Starter
DALJetDoc is on a distinguished road
Cam Position Sensor
hey i was just wondering.....I have a '01 330ci and it has a check engine light pertaining specifically to the cam position sensor.....i heard that theres a history of problems with that sensor on my year car.......does anyone know if its usually a hard sensor failure or just an indicated failure that could be corrected by taking out the sensor and cleaning the contacts, etc?
DALJetDoc is offline
post #2 of 5 (permalink) Old 09-23-2009, 09:06 AM
Quoted: 1 Post(s)
Normally, it is a hard sensor failure, but it would not hurt to take it out and clean it. If you end up needing the sensor, you can find it here. It is not an expensive part so it might just be worth replacing it.
FCP Groton
877-634-0063 |
- European Car Parts Specialists
- Import Replacement Car Parts
FCPGroton is offline
post #3 of 5 (permalink) Old 09-25-2009, 12:25 PM
Steve8212 is on a distinguished road
Greetings FCPGroton,
Is there a troubleshooting guide to determine if the sensor is bad or not? (resistance on terminals) I dont mean to hijack this thread but you responded to my thread and I have a 325e 1987 with TWO sensors.
Are these identical?
Which plug on the wiring harness goes to which sensor? (color coded)?
Thanks
Steve
Steve8212 is offline
post #4 of 5 (permalink) Old 09-25-2009, 02:54 PM
Quoted: 1 Post(s)
More then likely, they are not identical. As for testing them, they work like an on-off switch. As it spins, it should send a signal like a syn wave. The faster it spins, the higher the frequency. I am not sure as to the best way to test them with out a oscilloscope.
FCP Groton
877-634-0063 |
post #5 of 5 (permalink) Old 09-25-2009, 05:10 PM
I do have a scope. The part number calls for TWO for this model with the same number and I was told the car will run without the speed sensor but not the CAM position sensor. I will swap and test this weekend.
Does the paperwork on the sensor indicate any type of resistance between the terminals for a quick check out?
Thanks for all your help...
Steve
p0304 position sensor rudeboyslim New Members Check In 9 09-06-2009 12:33 AM
Camshaft Position Sensor gigsy 5-Series (E12,E28, E34, E39, E60) 1 10-24-2005 01:08 AM
Hesitiation.mass Airflow Sensor Or Cam Pos Sensor? scopefrfd 5-Series (E12,E28, E34, E39, E60) 7 04-24-2005 12:47 PM
Cam Shaft Position Sensor EuRopE1981 3-Series (E46, E90) 15 03-24-2005 08:03 PM
Cam Position Sensor, Which Code? jehu3 3-Series (E46, E90) 0 09-28-2004 04:01 PM
