A/C Cuts out when it rains - BMW Forum - BimmerWerkz.com
Old 08-13-2003, 08:24 PM   #1 (permalink)
nseverin is an unknown quantity at this point
My AC cuts out in my 1999 323i when it rains or the car gets wet.
Is this normal, or is there a sensor I need to check?
can anyone help.
Thank you.
nseverin is offline   Reply With Quote
Old 08-13-2003, 08:46 PM   #2 (permalink)
AZ325Ci is on a distinguished road
welcome aboard, nseverin!! B)
to tell you the truth, i'm lost on your a/c situation. i have never heard of that. maybe there will be someone here that have had that or will know what to do.
personally, i would just take it in to the service and have them run a diagnostic to see if they can locate the problem.
AZ325Ci is offline   Reply With Quote
Old 08-13-2003, 08:50 PM   #3 (permalink)
DesmoBob's Avatar
o that is definitely not normal.
does the airflow completely stop? or do you still have airflow, but it is just not cold?
i ask because i am thinking if there is air (but it is warm), there may be a short to ground with one of the wires running to the compressor or compressor relay. check fuses 16 and 39, which go the compressor relay, which in turn controls the compressor.
i had a problem once when i hosed down the engine bay, and my a/c stopped getting cold. it turns out the water grounded a frayed wire against the compressor body.
Old 08-13-2003, 09:01 PM   #4 (permalink)
The compressor turns off so it starts to get warm in the car.
Thanks for the response I'm going to check the wires right now
Old 08-13-2003, 09:09 PM   #5 (permalink)
L337E46's Avatar
L337E46 will become famous soon enoughL337E46 will become famous soon enough
can anyone help.
Thank you.
Has your 323 ever been in a front end collision?
General, Troll Warfare Center: Task Force Troll/Founder BMW FORUMS 3.1415926535897932384626433832795 CLUB/Board Member Brotherhood of Huzzah/Board Member Troll Assassin Board/Board Member W00t! Club/Campaign Director Yanosh for President/Founder L337 Flash Club/Founding Member BMW Forums V1 Club/ BMW-Forums Badger Badger Badger arrgggghhhhhh club
L337E46 is offline   Reply With Quote
Old 08-13-2003, 09:12 PM   #6 (permalink)
no it hasn't
Old 08-13-2003, 09:18 PM   #7 (permalink)
L337E46's Avatar
How many miles does it have?
Old 08-13-2003, 09:20 PM   #8 (permalink)
it has about 120,000 km which is about 65000 miles
Old 08-13-2003, 09:23 PM   #9 (permalink)
L337E46's Avatar
My A/C compressor clutch went out @ 47k miles... I actually had the Fan working but the A/C was totally out. Check that out.
Old 08-16-2003, 04:04 PM   #10 (permalink)
1. clutch switch gets wet and shorts
2. the little tube that leaks condensation out is clogged.
3. some other short somewhere.
this sounds like the compressor itself is ok.
peter
Old 08-16-2003, 06:32 PM   #11 (permalink)
EXtech's Avatar
check for obvious bad connections or shorts. Check the pressure switch on the drier behind the pass. headlight
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
how do you get the a/c off ? j123crx 3-Series (E21, E30) 1 10-15-2005 04:03 PM
Remote Start Cuts Off CellFreedom 3-Series (E36) 6 09-06-2005 08:57 PM
Rear Seats Wet After It Rains?? sy5alive 3-Series (E36) 9 01-20-2005 10:46 AM
Car Randomly Cuts Off shorty28546 3-Series (E21, E30) 4 10-15-2004 11:36 PM
diamond cuts bimmerfan620 Picture Showroom 16 04-04-2004 12:15 AM
