A/C Blows hot after about thirty minutes. - BMW Forum - BimmerWerkz.com
Old 08-14-2006, 09:14 PM   #1 (permalink)
Sugarmel is an unknown quantity at this point
My 325 E46 (2001) A/C blows cold for about thirty minutes,then turns to hot on it's own. Can this be an evaporater problem? Any help is appreciated.
Sugarmel is offline   Reply With Quote
Old 08-14-2006, 09:32 PM   #2 (permalink)
DIRTE30's Avatar
DIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond reputeDIRTE30 has a reputation beyond repute
Send a message via Yahoo to DIRTE30
Does it have auto climate controll? If so, I'd say you have a climate control computer or sensor issue. You should have the dealership look to see if there is a TSB for this (technical service bulletin) or even a recall. If nothing else they can tell you if the symptoms are indicative of a common problem that they see.
DIRTE30 is offline   Reply With Quote
Old 08-15-2006, 12:33 AM   #3 (permalink)
Moderator
Dirty_Tool's Avatar
Also could be an issue with the evaporator icing up. Either way AC problems are usually best left to the professionals with the proper equipment to service Air Conditioning.
DT
Old 08-15-2006, 07:05 AM   #4 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Your car might also have reached the temperature you told it to reach in the automatic climate control system?
Lindsay fan club member.
