Brake warning light; radio stops working; A/C/ stops - BMW Forum - BimmerWerkz.com
Old 06-10-2011, 10:56 AM   #1 (permalink)
Car: 2005 325 XI
Yeorgos is on a distinguished road
I have a 2005 325XI. about two-three weeks ago, as i was driving, the yellow exclamation point light would come on, the "brake" light; "ABS" light; the radio would stop working; A/C stops. last a few seconds and would go away. The other day, same thing happened but transmission indicator came on. I turned car off and started it again everything appeared normal. what the hell is going on? I read it may be bad ignition switch, maybe the brake pedal is rubbing against wires, IDK...any help ???
Yeorgos is offline   Reply With Quote
Old 06-17-2011, 10:14 PM   #2 (permalink)
zibby's Avatar
Car: yes
Your battery is on its way out or ignition switch start failing.In my case was ignition switch.I would go with ignition switch first ,easy to replace and inexpensive.My battery
kept going for 11 years,yes 11years!!! your battery is just 6 years old, should be fine,but you never know.Good luck!
http://www.q8oils.it/
Old 06-18-2011, 09:27 AM   #3 (permalink)
Captain... Savvy ?
Jack Dabsy's Avatar
Good answer...
BMW's want ampage 'cos they're greedy Germans lol
Eso es todo!
BMW Part Market
BMW Online Manuals (TIS)
New Member ?
Car misfiring and 1 random injector stops working compleatly otownvan 3-Series (E46, E90) 2 02-21-2010 02:28 PM
Engine starts then stops Queball 1,6,7,8 - Series and Mini Cooper 0 04-05-2009 06:02 PM
Engine stops while driving my328ci 3-Series (E46, E90) 0 06-14-2007 12:14 PM
it works one minute, then stops. WTF! bimmerguy82 3-Series (E36) 2 07-05-2006 12:35 PM
Heater stops working gman 3-Series (E36) 3 03-10-2004 02:14 PM
