brake pad sensor - BMW Forum - BimmerWerkz.com
Old 11-14-2008, 05:43 PM   #1 (permalink)
hbbodley is on a distinguished road
brake pad sensor
Is it necessary to replace the sensors when you do a brake job? Im not sure if they are one time use or not.
hbbodley is offline   Reply With Quote
Old 11-14-2008, 05:49 PM   #2 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
I replace them every time. However, you only HAVE to replace them if the brake pad wear indicator light has tripped. Otherwise, you can reuse the same sensor.
Turkey Fleet Bond Holder
Old 11-14-2008, 08:00 PM   #3 (permalink)
TRuckee is an unknown quantity at this point
drz is right (again) on this. The sensor is a device that wears through and opens a normally closed circuit to indicate pad wear. If you've worn your pads enough to cause the OBD system to know it, the sensor is "toast".
TRuckee is offline   Reply With Quote
Old 11-15-2008, 09:23 AM   #4 (permalink)
Thanks for the info.
Brake pad wear sensor wire? da_bull 5-Series (E12,E28, E34, E39, E60) 11 09-19-2006 05:00 AM
Brake Pad Sensor ctm78 3-Series (E46, E90) 11 08-15-2005 05:19 PM
Brake Pad Sensor coprtim 3-Series (E46, E90) 2 06-24-2005 06:43 AM
Brake Pad Sensor Wires SuperFreaks 323is 3-Series (E36) 11 03-09-2005 11:40 PM
Brake pad bmwjx 3-Series (E36) 0 12-31-1969 07:00 PM
