Brake job - Rotor Question - BMW Forum - BimmerWerkz.com
Old 07-25-2008, 12:01 AM   #1 (permalink)
stonewal32 is on a distinguished road
HI, I am new to owning a BMW. I just bought my first one, a used 2002 325i with 58,000 miles.
My light just came on to do a brake job.
So I ordered the professional grade pads from Checker.
Then I heard that often you have to replace the rotors and the sensor at the same time. I have never had to replace rotors unlessed they were visually damaged.
Questions:
1. Are the checker professional brake pads any good? Should I return them and get something else? They cost about $50.
2. Do I need to replace the rotors even if they do not look worn?
3. Do I need to replace the brake sensor even if it does not look damaged?
I don't want to spend more money than necessary, but also do not want to comprimize the braking ability.
stonewal32 is offline   Reply With Quote
Old 07-25-2008, 12:52 AM   #2 (permalink)
If I need rotors, what rotors would you recommend?
Old 07-25-2008, 09:24 AM   #3 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Smile
<<< they're as good as any... but there are different grades. the lowest quality ones put out brake dust which may be unsightly; whereas the newer ceramic brake compounds offer quieter braking and less brake dust.
<<< no, you dont need to replace them. If they look scored, u can have them turned at a local shop for about $20.- if u wish to regain a smooth rotor surface. Consider also... if u feel any type of vibration when u brake, your rotors are warped-Rotor warp if minor can turned; otherwise, if the run-out is too much, then replace is the only remedy.
3. If u can transfer them onto the new pads without causing damage to them, by all means-do so
Old 07-25-2008, 09:58 AM   #4 (permalink)
iamcreepingdeath's Avatar
Car: 1995 325i and 1991 318is
iamcreepingdeath is on a distinguished road
You don't need new rotors to replace your pads. you only need new rotors if your rotors are warped or scored visually. You can tell if they are warped if your steering wheel wiggles back and forth during braking.
You do need to replace brake sensors. Your brake light came on because your brake sensors have been worn to their little metal contacts, and they need to be replaced. you can get those at bavato.com for pretty cheap.
Pads from an auto parts store might not be the best idea for a BMW. I would look at what bavauto.com has to offer.
iamcreepingdeath is offline   Reply With Quote
Old 07-28-2008, 06:30 PM   #5 (permalink)
Car: 2001 320i
rockhall is on a distinguished road
I did the cheapo brake pads on my 320i the sensors did not fit properly and the sensor light does not go off cost us another set of pads and sensors from BMW
rockhall is offline   Reply With Quote
Old 07-29-2008, 07:30 PM   #6 (permalink)
dslim88 is on a distinguished road
Just replace it all
I would replace everything (pads, rotors, and sensors) since you just bought the car that way you'll know everything is good to go. I just did my 2000 328Ci, it wasn't hard (was my first time). I ordered everything from bavauto.com for less than $350. Great website with excellent customer service if you don't see something just call them they have everything.
A couple of links to help you out:
Doug&apos;s Domain :: BMW Brake Replacement DIY
E46 Brake Pad and Rotor R&R
dslim88 is offline   Reply With Quote
Old 07-30-2008, 09:26 AM   #7 (permalink)
aampsmb is on a distinguished road
Replace all parts
Just replace all the parts. Pads, rotors, and sensor wire. I did my wifes 2000 323I for a total of $165.00 from BavAuto.com. The parts came from Germany. Very good quality. I used the Mintex pads and the brake dust was noticable less than the stock pads. Good luck.
aampsmb is offline   Reply With Quote
Old 07-31-2008, 07:32 PM   #8 (permalink)
Car: 2001 bmw 325i with sport pkg
damian846 is on a distinguished road
just a tip.. i purchased pads, rotors and sensor form the dealer.. and to tell you the truth im not to happy with them..they sqeak and give out ALOT of dust..i cant keep my rims clean for more than 2 days...
damian846 is offline   Reply With Quote
Old 08-01-2008, 06:43 AM   #9 (permalink)
The dealer probably installed OEM pads and rotors. The squeaking is from not putting brake pad grease on the back of the pads before installing them. I forgot the grease too and they squeak.
Need advise removing brake rotor TRuckee New Members Check In 2 07-02-2007 10:13 AM
WTB 87-91 325ix rear brake rotor/disc Slow325i Looking For 1 11-14-2006 12:39 PM
Brake rotor repaced. Steering wheel vibration Five-2.8i 5-Series (E12,E28, E34, E39, E60) 11 05-04-2006 12:51 PM
Brake Rotor Nut Jetski 3-Series (E36) 8 07-21-2005 09:55 AM
Brake Pad & Rotor Reviews sardar 3-Series (E46, E90) 5 04-15-2005 12:44 AM
