Brake fluid change service indicator reset? - BMW Forum - BimmerWerkz.com
Old 08-22-2006, 06:20 PM   #1 (permalink)
Phillip Biggs is on a distinguished road
Question Brake fluid change service indicator reset?
Hi, hope someone can help. I've just completed my first Inspection I service and the car still works. That's the good news. My question is, does anyone know how to remove the little clock symbol service indicator that tells you that a brake fluid change is required?
I've reset the oil change / inspection I service indicator using the turn key press left button technique, but is there a similar method to get rid of the brake fluid change symbol?
Phillip Biggs is offline   Reply With Quote
Old 08-22-2006, 09:37 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Same method actually...when your little clock symbol is on it will only change the clock symbol and not effect the SIA.
Come see me at MySpace
Old 08-24-2006, 09:21 AM   #3 (permalink)
Brake fluid change indicator
You're right. Thanks very much for that. I had the Inspection I and brake fluid reminders on at the same time. The first reset had got rid of the Inspection I but I had to do it again as you suggested to clear the brake fluid timer.
Thanks again.
Old 08-24-2006, 10:32 AM   #4 (permalink)
Hootie is on a distinguished road
There is a brake fluid timer similar to the oil and inspection? How does one locate such a timer and what does it take into account while counting down?
Hootie is offline   Reply With Quote
Old 08-24-2006, 11:25 AM   #5 (permalink)
The timer is a small clock symbol (about 4 x 4 mm) central on the same display as the service indicator / mileometer. It's described I believe in the handbook. I think it's an entirely time based display (comes on every two years) and doesn't take into account driving style like the other service indicators do.
Old 08-24-2006, 09:13 PM   #6 (permalink)
325isBaby's Avatar
Car: 2005 330xi
To be totally honest I have only seen these on the E36s
$8.00 Power Steering Fluid Change acoustic 3-Series (E36) 0 05-18-2006 01:11 PM
Brake Fluid Change Service Indicator Boxbrownie 3-Series (E36) 4 02-20-2005 04:02 AM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
