BMW SIDE BLINKER INSTALLATION?? - BMW Forum - BimmerWerkz.com
Old 01-12-2004, 09:27 PM   #1 (permalink)
H4X0R JsM is an unknown quantity at this point
Hey fellaz. Just got a pair of eurosmoke side blinkers for my E46 325I Bimmer, have looked a little at the amber sidemarkers already on there, and didn't want to start prying at them until i was sure on how to properly remove them and install the new ones. Anyone know how this works ?
Thanx fellaz, - Shane
H4X0R JsM is offline   Reply With Quote
Old 01-12-2004, 10:30 PM   #2 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
sidemarkers: just gently pry out with a flathead screwdriver. * you may want to use a credit card to start the prying, then use the flathead. The credit card prevents paint scratching. Once off, twist the bulb a quarter turn to take off, then quarter the other way to lock them. Pop the sidemarker in and you are done.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 01-13-2004, 08:20 AM   #3 (permalink)
couper is an unknown quantity at this point
I believe you can push the lens--towards the front --and then it should pop out of the fender
couper is offline   Reply With Quote
Old 01-13-2004, 02:35 PM   #4 (permalink)
el_bandito is an unknown quantity at this point
http://www.kingwoodcable.com/cy_clone/bmw/.../clear_DIY.html
Here is a set of instructions for installing a complete clear lens set......instructions for side markers are down a bit. Hope this helps.
R
BMW - With great power comes great responsibility.
el_bandito is offline   Reply With Quote
Old 01-13-2004, 03:05 PM   #5 (permalink)
CBA
CBA's Avatar
CBA is an unknown quantity at this point
Send a message via MSN to CBA Send a message via Yahoo to CBA
you might wanna try placing a rag on that credit car or flat head that your gonna use to remove that marker with.. even a credit card can put a scratch in the paint doesnt take much all you really need it for is its flewibility to contour to the side of the car.
all you ever need for the toronto night life <a href='http://www.spotlighttoronto.com' target='_blank'>click here</a>
<img src='http://www.spotlighttoronto.com/forum/templates/DigitalDementia/images/header.jpg' border='0' alt='user posted image' />
you know your not paying attention when this happens:
<div class='quotetop'>QUOTE</div><div class='quotemain'>Are you refering to his Signature? oh shit, i just remembered i used my name in my sig... I just 0wn3ed myself. </div>
-Founder
CBA is offline   Reply With Quote
Old 01-13-2004, 07:58 PM   #6 (permalink)
Troop705 is an unknown quantity at this point
S/B able to just get a firm grasp on the marker and slide it forward, that should release the tension spring. Try that first before using a screw driver. When I changed mine that's all it took.
2000 323i premium pkg, xenons, oem clear corners &amp; sidemarkers, tint, k&amp;n filter, oem chrome tail pipes, heated seats
Troop705 is offline   Reply With Quote
Old 01-13-2004, 11:24 PM   #7 (permalink)
TECH's Avatar
You stick a screwdriver down into the hole from the top, push down on the tab, and slide out. If it's a later style, unscrew the phillips screw that is down that same hole, and slide out.
PRY?!
No wonder the things fall out onto the road. used
Old 01-13-2004, 11:55 PM   #8 (permalink)
^ hes talkin about the sidemarkers, not the front corner
Old 01-14-2004, 07:38 AM   #9 (permalink)
TECH's Avatar
Oh. :P
Old 01-14-2004, 04:32 PM   #10 (permalink)
SevenPlaces4all is an unknown quantity at this point
I did this installation recently...
I just used a flathead screwdriver and wrapped it in a 100% cotton t-shirt. The shirt was thin enough that it didn't create an obstruction for prying it free. After that you just kinda push it in and pry it open at the same time... trial and error, just don't use too much force or the side indicator will snap in half, haha.
http://www.bimmian.com has installation instruction VIDEOS if you click on "clear lens kit"
SevenPlaces4all is offline   Reply With Quote
Old 10-04-2004, 06:32 PM   #11 (permalink)
notabmwowner is an unknown quantity at this point
Hey guys, I like the side markers that you have on the e46 325i and would like
to put them on my Tiburon, the pointed ones. But I need to know how big a hole
I can cut into my fender for them. If anybody can give me the dimensions, it would be much appreciated.
notabmwowner is offline   Reply With Quote
Old 10-04-2004, 08:41 PM   #12 (permalink)
KillFox is an unknown quantity at this point
Send a message via AIM to KillFox Send a message via Yahoo to KillFox
That depends on which ones you like, the pre 2002 are skinnier, and the post 2002 look more like an arrow.
Which do you prefer?
<img src='http://3dwire.net/~matt/killfoxsig2.gif' border='0' alt='user posted image' />
KillFox is offline   Reply With Quote
Old 10-06-2004, 04:49 PM   #13 (permalink)
[snapback]204904[/snapback]
The ones that are like an arrow.
Old 10-17-2004, 07:05 PM   #14 (permalink)
Trinity is an unknown quantity at this point
I was wondering the same thing. I have an older model BMW without sidemarkers and I love the clear sidemarkers for the 03-Up 330ci. I ordered a set and now I have to install them and I don't know how I should go about cutting the fenders because I need a pattern to cut for the hole. Could anyone who has these sidemarkers help me out by tracing the hole in the fenders of you car so I know just what pattern to cut for a good OEM fit? I'd really appreciate it. Just remove one of your sidemarkers and trace the pattern on a piece of paper and either scan and e-mail it or mail it. I'd me most appreciative.
Trinity is offline   Reply With Quote
Old 10-17-2004, 07:11 PM   #15 (permalink)
sean's Avatar
sean is an unknown quantity at this point
Send a message via AIM to sean
[snapback]74808[/snapback]
yah this is all you have to do on the ones i have seen and/or done myself
<img src='http://img.photobucket.com/albums/v146/318ibmw318i/the_sig.jpg' border='0' alt='user posted image' />
signature designed by crisby_E30
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>
<span style='color:red'>Chairman</span> of the &quot;BMW-Forums...Cant hack it? Go Whack it... &quot; Mafia...&quot;We'll take your shoes&quot; </span></span>
sean is offline   Reply With Quote
Intermitient Operation Of Drivers Side Door Window mudilik 5-Series (E12,E28, E34, E39, E60) 1 08-18-2005 09:56 PM
side skirts installation? leobmw 3-Series (E36) 1 03-25-2004 11:41 AM
