Bmw E46 Rear Noise When Engaging Clutch And Gears 1 & 2 - BMW Forum - BimmerWerkz.com
Old 11-17-2009, 01:36 PM   #1 (permalink)
manhuwa is on a distinguished road
Hi Guys
i have a BMW E46 2000 model , i have a problem with it, when i engage gear 1 and gear 2 or take off at low speed there is clunking noise which comes from the rear wheels, particularly the left rear passenger side. Even just stepping on the clutch when stationery a clunking noise comes from the rear passenger`s side, does anyone know what this could be, i appreciate your help. The noise is not wheel bearings definately,as it happens when changing gears, or when stationary if you press the clutch
manhuwa is offline   Reply With Quote
Old 11-17-2009, 03:05 PM   #2 (permalink)
How are your drive line mounts?
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 11-25-2009, 04:47 AM   #3 (permalink)
NWS BMW e46 REAR NOISE
I went with my BMW to an independent specialist who said there was no problem with it, they checked the diff and rear wheel drive components and said the noise is normal all Bmw 3 series do it later on and i have to live with it. i dont trust that, surely the car shouldnt make rear noise when you engage gears, drive over speed bumps or potholes, it makes some humming noise the same like that of a blown exhaust, what worries me is the car make this noise from the rear wheels, even when stationery and you engage gear you hear a humming noise, the car drives fine other than that, has anyone ever experienced this and did they manage to solve it ? please help
PLEASE HELP
Old 12-14-2009, 11:10 AM   #4 (permalink)
luke1925 is on a distinguished road
the clunking noise is most likely the rear differential mount. i had the same problem on my bimmer.
luke1925 is offline   Reply With Quote
Old 12-14-2009, 07:03 PM   #5 (permalink)
roma's Avatar
roma is on a distinguished road
E46 rear end frame bushing faulty ,i think is recall,idk
roma is offline   Reply With Quote
Old 09-21-2010, 12:44 PM   #6 (permalink)
haggitu is on a distinguished road
Hi!
I'm new in this forum and i was looking answer to my question on internet and found this place. Have you got answer to your problem? I have same problem, when i put 1st gear in when standing rear axle will make "pump" noise, when i press clutch pedal it sometimes makes same noise. I have repaired my rear frame problem and welded it so it can not be the problem. I my self am suspicious about rear U-Joint, as it makes little kicking noise when i turn drive shaft little bit.
Please help me as i have run out of ideas
Excuse my bad English as well!
haggitu is offline   Reply With Quote
Pictorial DIY: BMW E46 Fan Clutch Removal & Engine Belts Change For Automatic Cars Delmarco FAQ's and DIY's 8 08-06-2009 07:43 AM
gears and clutch dudehog 3-Series (E36) 3 02-07-2009 03:15 PM
Weird Noise Between Gears timmy328is 3-Series (E36) 7 12-25-2004 07:44 PM
Changing gears without clutch ? Q_BMW 3-Series (E36) 35 07-01-2004 10:06 AM
e36 & e46 rear shock mounts pooskay 3-Series (E36) 0 12-04-2003 12:18 AM
