BMW Alarm and lights - BMW Forum - BimmerWerkz.com
Old 01-21-2004, 01:35 PM   #1 (permalink)
steveyang24 is an unknown quantity at this point
My lights do not light when the alarm is armed or unarmed. Also, the status light under the rear view mirror does not work. DOes any one have suggestions on how to get these to work. It's not the fuse, I've already checked them.
steveyang24 is offline   Reply With Quote
Old 01-21-2004, 01:50 PM   #2 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
when you arm/disarm, does it chirp like an alarm should, if so then you have the alarm. if not, you do not have the alarm
it is most likely that the flashy lights and the 'clown nose' are not programmed into the alarm system. the only way is to go to your local dealer to get it programmed.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Old 01-21-2004, 02:37 PM   #3 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
you probably don't have an alarm. my car did not come with one but it is prewired for a factory one.
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 01-21-2004, 07:46 PM   #4 (permalink)
TECH's Avatar
Yep, what he said. But if you do have an alarm, I believe they can be programmed to flash or not, to honky honk or not.
Maybe your hood switch isn't working.
Factory Alarm & Battery chily3 3-Series (E36) 6 09-29-2005 04:50 AM
E36 Floorboard Lights Installed! Delmarco 3-Series (E36) 7 08-20-2005 12:18 AM
Dash Board Lights Goes Out goochdy M-Series (M1, M3, M5, M6) 0 03-09-2005 04:21 PM
OEM Alarm jennsydandrew 3-Series (E36) 4 01-29-2004 12:54 PM
