Originally Posted by jasonss03 just had my a/c blower stop blowing air for no reason and then came back on about a minute later. anyone experiance this problem before and what could be the cause? the digital a/c monitor was still working fine just the blower stopped working. |
if it happened only one time... let it ride. shut everything off. And let us hope it was just a computer glitch. If it dsnt re-occur... don't worry about it
Check also how it operates at different blower speeds. does it cut -out only at a specific level?.. or maybe all levels?
if it does happen again, then observe the operation of the blower. i.e. does it sound normal? or does it drag? what about if the system is in defrost or HEAT...? does it do the same thing?
answers to these questions as best you can will help pinpoint your prob.
