Blower fan noise - BMW Forum - BimmerWerkz.com
Old 04-18-2006, 08:53 PM   #1 (permalink)
Black2000328i is on a distinguished road
Blower fan noise
Hey guys. My cabin blower fan makes chirping noises at
intermittent intervals. This is very anoying when it happens.
It always happens when it's under 60 deg.F outside. I never
makes this noise when it's warm or hot out. It doesn't chirp
when car is first started but starts to make noise after driving
and car is fully warmed up. Has anyone have or had this problem
with their cars?
Black2000328i is offline   Reply With Quote
Old 04-19-2006, 08:39 AM   #2 (permalink)
441tech's Avatar
441tech is on a distinguished road
Yes, I too have had that problem. And, like your issue, it doesn't do it if its warm. There are a couple of things you can do.
1.
Officer: "I see you set the table for four."
Groucho Marx: "That's nothing--I set my alarm clock for eight."
441tech is offline   Reply With Quote
Old 04-19-2006, 08:40 AM   #3 (permalink)
Hootie is on a distinguished road
Hey tech... wanna finish that post?
Hootie is offline   Reply With Quote
Old 04-19-2006, 08:57 AM   #4 (permalink)
441tech's Avatar
1. Live with it.
2. Gain access to the blower fan and lubricate the rotating parts. Howver, this will probably only last 1-2 months or so.
3. It could could be the Final Stage Unit. To my understanding, this has solved the problem in the past for a few.
If you're going to go through the trouble of lubricating it, I would replace the final stage unit while you're in there. I'm showing a list price of approx. $83.70. Might be worth it.
441tech
Old 04-19-2006, 08:59 AM   #5 (permalink)
441tech's Avatar
Sorry, I'm at work and had a phone call.
Old 04-19-2006, 11:48 AM   #6 (permalink)
how do you gain access to this thing? for that matter, how do you gain access to the back of the stereo unit?
Old 04-19-2006, 12:30 PM   #7 (permalink)
zibby's Avatar
Car: yes
The blower motor is located behind the engine. You take the micro filter our and then the housing is removed by 4 torx screws. Behind that there is another black panel held on by two torx screws. Remove that then the fan is right there. There is one screw in the top and is hard to see. After you remove the screw remove the two clips and the front housing comes off. To remove the fan you just release the spring clip at the lower part of the fan motor.
P.S
When removing the fan you have to snake it out through the passenger side of the opening. Be carful not to break the fan, its plastic.
http://www.q8oils.it/
Old 04-19-2006, 06:10 PM   #8 (permalink)
325isBaby's Avatar
Car: 2005 330xi
yes, it is more likely it is a faulty final stage unit causing the chirp...and lucky for you it is easier to get to than the actual blower motor.
Come see me at MySpace
Old 04-19-2006, 06:50 PM   #9 (permalink)
zibby's Avatar
Car: yes
Just so everyone knows, the blower resistor for an E46 is on the passenger side of the center console almost against the firewall. You must remove the right footwell air duct and an air distribution motor to get to the resistor pack for replacement.
Z.
Old 04-19-2006, 08:22 PM   #10 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Thank you Zibby, I intended to put that but I tend to suffer from CRS
Old 04-19-2006, 08:50 PM   #11 (permalink)
zibby's Avatar
Car: yes
Your very welcome Lani !
Old 04-20-2006, 10:52 AM   #12 (permalink)
Hey Black, just to confirm it's your Final Stage Unit that's failing, does your blower also operate erratically (inconsistent flow of air)? That's another symptom.
Old 04-20-2006, 08:13 PM   #13 (permalink)
Hootie. The blower works fine on all speeds. Just makes chirping
noise which may last 5 to 10 seconds at a time. The thing is that
it doesn't do it in the warm or summer months. I'm bringing the
car at the dealer next week. Hopefully it will do it when driving
in the cooler morning temp's.
Old 04-21-2006, 05:11 PM   #14 (permalink)
441tech's Avatar
Nothin' a BFH wouldn't fix.
Old 04-21-2006, 09:24 PM   #15 (permalink)
325isBaby's Avatar
Car: 2005 330xi
I have seen them before where the blower speed remained consistant but had the chirping, it did turn out to be the final stage unit (so irratic blower is not always a sign of a failing final stage but however is the most common sign)
Noise in your system? da_bull Audio and Electronics 2 05-15-2013 03:27 AM
AC/heater blower fan control problem????? help gsrboy171 3-Series (E21, E30) 13 10-19-2005 08:59 AM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
Blower Motor Making Noise? green325is 3-Series (E36) 1 04-10-2005 01:46 PM
