Bad Vaccum Maybe? - BMW Forum - BimmerWerkz.com
Old 05-10-2005, 09:13 AM   #1 (permalink)
clarkinc is an unknown quantity at this point
I get a low volume high pitch foghornish squeal when I accelerate. It seems to only happen when the accelerator is in a certain position or the RPM is at a certain point. It doesnt seem to cause problems but is very annoying at the drive thru where you don't need alot of power to move to the next window even with the radio on. Can anyone help?
clarkinc is offline   Reply With Quote
Old 05-10-2005, 11:13 AM   #2 (permalink)
i take it that since you notice it at drive through's you don't have the radio on and the windows are open. thus meaning the noise prolly can't be herd all that welll with windows up and radio on. it sounds to me it is just the air going through the throttle body. all engines make this noise with the exception of diesel engines. it's just that some engines are louder than others. i have also noticed that for somereason even w/o a cold air intake BMW's are a little bit louder than most cars. but there is nothing wrong with your car. just turn the radio up a little louder.
Old 05-10-2005, 12:45 PM   #3 (permalink)
mankiks323i's Avatar
mankiks323i is an unknown quantity at this point
Not sure the same problom but i had a noise that would be intermitant when i turn off car alway a groaning sound not sure but also when i would drive it would groaning sound. It ended up being i think pcv valve little different it was under the intake manifold expensive fix. used
"What happens here stays here" Las Vegas
mankiks323i is offline   Reply With Quote
Old 05-10-2005, 04:19 PM   #4 (permalink)
Pandemonium Director
nukeduster's Avatar
Car: turbo 325is, 325es, Audi a4 turbo
[snapback]342955[/snapback]
you have a k&n filter? they cause whistling induction noises at certain rpms if you have a good ear.
Old 05-11-2005, 11:06 AM   #5 (permalink)
No, the breather element is stock.
Old 05-12-2005, 07:23 AM   #6 (permalink)
Hootie361 is an unknown quantity at this point
Send a message via AIM to Hootie361
I hear the same thing... right around 2,000 RPM? Like a high-pitch whistling... the volume changes depending on how much gas you're giving it? Mine is at it's loudest when the engine is trying to maintain speed, right about 2,000 RPM.
I've listened carefully and mine seems to be coming from under the center console, through the floor. I'm not sure what's under there that would be making the noise, but I assumed it was some sort of a vacuum leak as well.
Neither my old Honda or my Cavalier made this noise...nor do my friends cars. I find it hard to believe it's symptomatic of EVERY car.
Your Lane ------>
Hootie361 is offline   Reply With Quote
Old 05-12-2005, 08:16 AM   #7 (permalink)
as i said before all engines make this noise at some RPM just some are louder than others.if you took the air box off and reved the engine you would hear it on other cars too. the noise is most likely the air going through the throttle body. trust me as long as it is infact the air goign through the intake, which it definatly souds like that is the case here, there is nothing to worry about. although if any one feels the need to take thier car in to have a shop look at it by all means go aheand but they will prolly tell you the same thing.
Old 05-13-2005, 06:51 AM   #8 (permalink)
[snapback]343638[/snapback]
I would be inclined to agree if it were a slight squeal, which I also hear. However this is quite distinct and loud within an RPM window.
Old 05-13-2005, 07:09 AM   #9 (permalink)
Howie's Avatar
Howie is an unknown quantity at this point
[quote=clarkinc,May 13 2005, 11:51 AM]
I have a high pitch noise too when doing about 70-80 mph. The noise goes if I speed up or slow down, its just when maintaining speed.
Howie is offline   Reply With Quote
Old 05-14-2005, 09:03 AM   #10 (permalink)
[quote=Howie,May 13 2005, 06:09 AM]
[snapback]344064[/snapback]
Did they say that was normal?
Old 05-16-2005, 03:18 AM   #11 (permalink)
Howie's Avatar
They couldn't find a fault, but they could not replicate the problem when they were testing it... typical....!
Old 05-16-2005, 08:32 AM   #12 (permalink)
well if there was no faults then theres your first sighn that it probablly isn't all that important to worry about. and they probablly told you they couldn't duplicate it becasue they didn't want to get into trying to fix a problem that can't really be fixed.
Old 05-19-2005, 09:06 AM   #13 (permalink)
[snapback]344889[/snapback]
Well Bryan, the real problem is that it is very anoying at most. It ticks me off because as I ride down the street to turn into my driveway my car makes a loud signature noise that no doubt gets attention from the neighbors. I feel as if everyone is saying, thats a really nice beamer but it makes loud noises. Thats enough (I think) to want to treat a problem.
Old 05-19-2005, 12:54 PM   #14 (permalink)
EuRopE1981's Avatar
EuRopE1981 is an unknown quantity at this point
Send a message via AIM to EuRopE1981 Send a message via MSN to EuRopE1981 Send a message via Yahoo to EuRopE1981
Clarkinc try checkin the gaskets on the air flow system i had i had a problem with mine , the second gasket it was cut that was making the car make a noice symilar to yours.
EuRopE1981 is offline   Reply With Quote
Old 05-19-2005, 11:43 PM   #15 (permalink)
well honestly i don't know really want to tell ya. understandibly it is tough to really tell what it could be without actually hearing the noise. i guess you could just leave the car at the dealer and have them drive it untill they can duplicate the noise and go from there. you could maybe try test driving another car and see if that car also does it becasue i do know that most BMW's do have a slight whistle noise from the intake but it might be a diffrent noise than yours. oh and try finding a car that is atleast the same year as your as the bran new cars all have remodeld engines and they might not have the same noise as i am talking about.
