auxiliary fan - BMW Forum - BimmerWerkz.com
Old 11-12-2005, 12:22 PM   #1 (permalink)
mob_intl is on a distinguished road
Unhappy auxiliary fan
hi,
i have a serious problem and i seriously need help.....right after you crack from laughing...
My auxiliary fan is always on...always..even if the car is not on...i had to unplug the battery terminal to make it stop.
Did anyone have any similar problem...help wanted.
E 46 328 CI 2000.
mob_intl is offline   Reply With Quote
Old 11-12-2005, 02:46 PM   #2 (permalink)
zibby's Avatar
Car: yes
I'd say take a look at the fan resitor. Its mounted to the fan housing. Follow the wires from the motor to locate it.If it is a module thing you have to replace the whole fan unit because the module cant be replaced on its own.It is around $500.00 US for parts.
BTW there nothing to laugh about , it is a common problem on BMW with aux fans. It is normal question you have asked !
Old 11-13-2005, 08:11 AM   #3 (permalink)
I think it’s your rad temp sensor the DME controls the fan and if it looses it signal for the sensor it runs the fan, but the fan is permanently feed so it can run after the engine is off so it’ll run all the time
Old 11-13-2005, 02:26 PM   #4 (permalink)
EXtech's Avatar
There used to be a Technical Service Bulletin/Recall on the E46 Aux fans. As mentioned in a previous post, this was/is a common issue and involves replacing the module located on the fan housing. Under the TSB, warranty covered replacing the entire fan assembly which included the module.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Fan Delete chico_kj_23 3-Series (E36) 5 02-04-2010 12:40 PM
New here. Question about what fan noise could be.. torre 325i 3-Series (E36) 3 10-09-2005 03:28 PM
waterpump and fan? eclipsevrl 3-Series (E36) 3 09-30-2005 02:18 PM
How do you get the $#?!@ blower fan out of an E36? strubmw 3-Series (E36) 3 09-19-2005 06:13 PM
fan and thermostat sadubaba 3-Series (E36) 3 09-09-2005 10:42 AM
