Automatic Transmission Fluid / Steering Fluid - BMW Forum - BimmerWerkz.com
Old 08-19-2004, 05:11 PM   #1 (permalink)
akbarz is an unknown quantity at this point
About 2 months ago I heard a grinding / humming sound coming from my front wheels whenever the wheel was turned and the car was cold. I sort of ignored the sound, because as the car warmed up (about 30secs later) the sound would go away.
Recently the sound got worse and I called the local BMW Service center to inquire about causes and was told that it could possibly be the Power Steering Fluid being low. I was also told that the E46 (2000 323i) uses the same fluid for power steering and automatic transmission - same overflow bottle under the hood also. When I checked the overflow container it was dry! Which means that I had been driving my car with little or no Automatic Transmission Fluid / Power Steering Fluid for aprox. 2 months.
The question is how much damage have I done to my transmission? Any advise on this? Also, I suspect there is a small leak, does anyone know the aprox. cost to repair such a leak...anyone experience this before?
Cheers.
akbarz is offline   Reply With Quote
Old 08-23-2004, 02:04 AM   #2 (permalink)
gman16 is an unknown quantity at this point
we just made the repair to the power steering hose that was cracked. It was about $125 total labor and parts. You mcan see the hose underneeth the resevoir. Hope this helps.
gman16 is offline   Reply With Quote
Changing Auto Transmission Fluid billB 5-Series (E12,E28, E34, E39, E60) 8 10-11-2004 09:12 PM
Automatic transmission fluid in manual transmissio shield 3-Series (E21, E30) 3 09-22-2004 12:13 PM
Automatic transmission fluid Kiwi Russ 3-Series (E36) 1 07-03-2004 10:41 AM
Power Steering Fluid Aether 3-Series (E21, E30) 9 04-14-2004 04:20 AM
