Auto open/close sunroof problem - BMW Forum - BimmerWerkz.com
Old 03-10-2006, 10:29 PM   #1 (permalink)
Car: 2001 BMW 330Ci
QuieroFU is on a distinguished road
I just got a 2001 330ci couple of weeks ago and my sunroof is not operating correctly. The auto open/close function does not seem to work. When I try holding onto the button to open/close it, it does not work. All it does is open/close it a bit. The only way I can open/close the sunroof all the way is to press the button 6-7 times. The same goes with tilting the sunroof. I've also tried using the key on the drivers door to open it. All the windows open; however, i had no luck with the sunroof. Can anyone help? I live more than 200 miles aways from the closest bmw dealers so they are pretty much my last resort.
QuieroFU is offline   Reply With Quote
Old 03-11-2006, 03:35 PM   #2 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Do you hear the motor trying to activate with each touch of the switch? If so it would seem the motor is jamming or the switch is going bad...either one is an easy fix.
Come see me at MySpace
Old 03-11-2006, 10:20 PM   #3 (permalink)
Car: 2001 BMW 330Ci
The motor only responds each time I press the button. Holding onto the button does not do a thing. I'll at ebay for a replacement motor
Old 03-12-2006, 02:04 AM   #4 (permalink)
Moderator
Dirty_Tool's Avatar
Quiero,
PM me with your email and ill send you the initialization procedure for the sunroof motor. Its worth a try re-initializing it before buying a new motor or paying for diagnosis.
DT
DT
Old 03-12-2006, 01:27 PM   #5 (permalink)
Car: 2001 BMW 330Ci
I have already try that.
-Sunroof close
-key to position 2
-press tilt switch for 30 sec.
;however, no luck :
Old 03-27-2006, 02:46 PM   #6 (permalink)
Car: 2001 BMW 330Ci
got it fix all for 16 bucks!
got a new motor from ebay and fixed it my self all for 16 bucks.
Old 03-27-2006, 02:54 PM   #7 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
Sweet. I hope you stick around even now, after you have solved your problem.
Turkey Fleet Bond Holder
Old 03-28-2006, 09:31 PM   #8 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Congrats
Old 03-29-2006, 03:29 PM   #9 (permalink)
Car: 2001 BMW 330Ci
don't worry man.
I've order an add-on kit for the car and it'll be on tomorrow. I'll post some pictures after it's done. Does anyone know what might cause the check engine code P0172 and P0175? That was the reading after i got my oil changed.
Sunroof Noises Caused By Vibration. victorgallas 3-Series (E36) 0 01-20-2005 03:27 PM
sunroof problem B3M2W5i 3-Series (E36) 4 08-29-2004 10:50 PM
sunroof problem Black318IS 3-Series (E36) 1 08-19-2004 12:06 PM
sunroof problem Scarface 3-Series (E36) 19 05-22-2003 09:47 AM
