any common problems for E46's I should Know About??? - BMW Forum - BimmerWerkz.com
post #1 of 20 (permalink) Old 06-19-2006, 03:33 PM Thread Starter
Wonderboy's Avatar
Wonderboy is on a distinguished road
My Fiance has a 2001 330xi. Little 3 is pretty quick. Like the way it haddles. Any how she has some problems with the car and wants to get the nessecary ones fixed. How bad are the problems. are they weekend fixes or are they nightmares. Let me know please guys. Thanks much!!!
Wonderboy is offline
post #2 of 20 (permalink) Old 06-19-2006, 04:40 PM
red330Iperfpkg's Avatar
red330Iperfpkg is just really nice red330Iperfpkg is just really nice red330Iperfpkg is just really nice red330Iperfpkg is just really nice
Send a message via AIM to red330Iperfpkg
idk if its just my car or what but i have to replace quite a bit a fuses from time to time....radio cig lighter and one interior light...thats about it
sig done by SpeedInfusion
2001 740i sport
2003 330i ZHP
2003 M5
2005 A4 1.8T
2006 750Li sport
red330Iperfpkg is offline
post #3 of 20 (permalink) Old 06-19-2006, 05:03 PM
325isBaby's Avatar
what kind of problems is she having? Let us know to help you better
Come see me at MySpace
325isBaby is offline
post #4 of 20 (permalink) Old 06-21-2006, 10:38 PM
Phatrician is an unknown quantity at this point
I've had a 99 328i and now a 01 330i. On both of these, one or both of the blinkers (currently it's my right front) will go out intermittantly, causing the "fast blink" in my cluster.
Also, turning the radio or cd down from the steering wheel sometimes causes the cd track or radio station to change. This is especially annoying when I'm rocking out.
Both cars have been very solid otherwise.
E: I forgot to mention that when I hit the button forward to close the sunroof, 1 out of 100 times it will close all the way. I have no idea why this is.
2001 330i Sport
Phatrician is offline
post #5 of 20 (permalink) Old 06-22-2006, 12:36 PM
325isBaby's Avatar
the bulbs and sockets need to be replaced (due to scorching marks in the bulb housing common problem on E46) an extremely easy fix.
the controls on the steering wheels have cross-shorted and will have to be replaced (also fairly common) luckily an easy fix.
lastly-the sunroof probably needs to be re-initalized...have done by qualified person
None of these are detrimental problems just minor inconvienences
post #6 of 20 (permalink) Old 06-22-2006, 09:41 PM
FL325i is an unknown quantity at this point
'03 325i auto
In the shop last month for the fast blinker/burned out bulb and socket problem. Required some new wiring as well, which I haven't seen mentioned. One window regulator has been replaced.
FL325i is offline
post #7 of 20 (permalink) Old 06-23-2006, 12:55 PM
325isBaby's Avatar
it is rare to have to replace wiring for turn signals...
post #8 of 20 (permalink) Old 06-23-2006, 03:19 PM Thread Starter
Wonderboy's Avatar
what about noises during start up. Really odd noise. Never heard this before in any other vehicle. It doesn't just happen during any certain conditions either. It happens randomly. It sort of sounds like air being let out of a balloon whilr stretching the tip to make that funny sound. Yet a little more muffled. she has also replaced the battery and the alternator already. It does have relitively higher miles... 78,000. but still that should not effect the charging system all that much. Is her car plagued or what. Thanks for all the info so far peeps. keep it coming. It is really appreciated...
post #9 of 20 (permalink) Old 06-23-2006, 04:42 PM
BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3 BiGGm3
just got my car, only a month old. hope if anything happens it is minor
BiGGm3 is offline
post #10 of 20 (permalink) Old 06-24-2006, 11:39 AM
325isBaby's Avatar
I've seen cars with less mileage replace alt before they just wear out...and battery's are COMMON in BMWs (the thing you have to remember is a BMW has WAY MORE electrical need than alot of other cars) if she replaced the batt with an aftermarket make sure the 1) it has a vent hole 2) the vent tube is hooked up or it will start to rust out the trunk. 78,000 is fairly high in mileage, but there are guys on here that have more mileage than that (mostly in the E36 forum) From what you have told us, your g/fs car sounds to be in good condition (not plagued) Trust me I've seen FAR worse in my bay.
post #11 of 20 (permalink) Old 06-26-2006, 09:02 AM
Hootie is on a distinguished road
I have 93K miles on mine and my battery is just starting to go. I'm getting the DSC/ABS dash-lights about once a week... usually after it's sat a couple days.
Is that muffled sound coming from the air vents? Under the hood of the car? Just during startup or at other intermittent times too?
Hootie is offline
post #12 of 20 (permalink) Old 07-02-2006, 11:31 PM
Agreed! Didn't sound like it in my post, though!
FL325i is offline
post #13 of 20 (permalink) Old 07-10-2006, 12:41 PM
Ok, and I still have warranty on the 330i...should all these issues be fixed for the $50 deductible?
2001 330i Sport
post #14 of 20 (permalink) Old 07-16-2006, 03:55 PM
325isBaby's Avatar
Possibly, it really depends on your dealers labor rate...sorry couldn't be more specific.
post #15 of 20 (permalink) Old 07-25-2006, 04:55 PM
roca is on a distinguished road
I am having problems with my gas gauge what to do to fix problem is that the cluster itself or a bad sensor
roca is offline
Any Common Problems With A Euro-spec 320i? BYOCOM 3-Series (E36) 0 04-10-2005 10:19 PM
Common Problems... dberger 5-Series (E12,E28, E34, E39, E60) 0 12-13-2004 09:33 AM
E39 Common Problems List CosmosBlack 5-Series (E12,E28, E34, E39, E60) 16 11-22-2004 03:40 PM
