Ambient Temp Sensor - BMW Forum - BimmerWerkz.com
Old 06-18-2004, 05:06 PM   #1 (permalink)
rkendry is an unknown quantity at this point
Hello everyone, i'm a noobie and i'm already having issues. but it's ok i like the challenge.
another little problem that i have is the temp sensor that sits under the front bumper on the driver side (is that clear? i'm getting confused)
the sensor and the plastic is gone. the dealer said that it is common for that to happen. so i got the sensor.
does anyone has any tips or instructions for this project?
with the sensor gone my computer is reading -40 degrees and it's throwing off my AC. and it's pretty hot in florida.
thanks for spreading the knowledge.
rkendry
2000 323i
rkendry is offline   Reply With Quote
Old 06-18-2004, 06:16 PM   #2 (permalink)
Relevart's Avatar
Relevart is an unknown quantity at this point
I found this on another BMW forum, hope it will help you:
http://forum.e46fanatics.com/showthread.php?t=130496
Relevart is offline   Reply With Quote
Old 06-18-2004, 11:56 PM   #3 (permalink)
thanks
that sounds that'll work.
Old 06-23-2004, 12:37 PM   #4 (permalink)
another quick question.
how long does it take for the temp to reset? i installed the sensor a couple of days ago but it's still reading -40degrees. all the conections seem fine. do i have to do something else than just installing it?
Old 06-23-2004, 01:06 PM   #5 (permalink)
Gargoyle69's Avatar
Gargoyle69 is an unknown quantity at this point
Might want to check the passenger side wheel well. I have a 2000 model 323i and it has a sensor for the out-side temp on that side aswell. Just a thought, if yours has two like mine and one of them is bad then it might be throwing it off, like when you lost the other one maybe the passenger side tried to compensate and bvurned itself out. Who knows?
Silver 2000 323i with sport package
Gargoyle69 is offline   Reply With Quote
Old 06-23-2004, 11:09 PM   #6 (permalink)
you're right, there is another sensor on the passenger side. it's round about the size of a half a dollar. it looks intact. could that be the problem?
Old 06-24-2004, 06:26 AM   #7 (permalink)
Gargoyle69's Avatar
That is a possibility. You might try and test it, if you have a ohm meter. Hope this will lead you closer to the truth of the problem.
Ambient Temperature Sensor Tacorom6969 3-Series (E36) 7 07-17-2005 01:42 PM
Help Please! Ambient Sensor Assembly sdfighter1 5-Series (E12,E28, E34, E39, E60) 3 11-08-2004 10:44 AM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
New Car - Few Problems, Any Help Appreciated. Sagan 3-Series (E36) 8 05-16-2004 09:28 PM
question about aimbeant temp sensor zombo14 3-Series (E36) 3 04-15-2004 09:51 PM
