Alarm System for 2000 323 CI - BMW Forum - BimmerWerkz.com
Old 10-20-2003, 08:51 PM   #1 (permalink)
kkevin77 is an unknown quantity at this point
I recently just bought a 2000 323 CI and the alarm system doesn't seem to be working. I bought the car used from Carmax. The red alarm indicator light under the rear view mirrow isn't flashing when I lock the doors and the motion sensor doesn't seem to be working as well. Carmax will pay for the cost to fix. My question is if anyone knew how hard it is to fix the problem and what might be causing the problem? Also, can this be done in a day or what? I am a first time BMW owner and would appreciate any feedback. Thanks
kkevin77 is offline   Reply With Quote
Old 10-20-2003, 09:43 PM   #2 (permalink)
AZ325Ci is on a distinguished road
are you sure that there is an alarm system installed? does the siren go off if you bump it?
the motion detector is located in the above center of your headliner. just pop that off and see if you have a system in it. if there is one, make sure the wires are connected. it doesn't take long to fix it.
btw, welcome aboard!! B)
AZ325Ci is offline   Reply With Quote
Old 10-20-2003, 09:47 PM   #3 (permalink)
No, I am not sure if there is one installed or not. I just assumed there was but I guess I was wrong. I apologize for the stupid questions I'm about to ask but what and where is the headliner?
If there is not system, what sort of alarm do you recommend thats easy to install and at a reasonable price?
Thanks
Glad to be on the board. Excited about my BMW purchase. Can't wait to learn more.
Old 10-20-2003, 09:58 PM   #4 (permalink)
no problem, there are no stupid questions. i am glad to be of help. :wink
the headliner is the roof of your interior. if you are inside, look above you. you should see a small square box in the center. just pry that open from the corner and see if you have the motion detector in there. if not, then you do not have the alarm system.
i have posted in your other thread, so i'll post again.
if you choose to go with the factory alarm, you should go to http://www.pacificbmw.com or http://www.circlebmw.com. they have the best prices on OEM parts.
another alarm system that is good for BMW's, is the Stellar system. you can find that at http://www.bavauto.com
the factory alarm system is relatively easy to install, so i've heard. i haven't installed one on mine yet. can't wait to get it. i am sure that the Stellar system installation is about the same, not sure.
Old 10-20-2003, 10:02 PM   #5 (permalink)
Appreciate all the info. thanks a lot
Old 10-21-2003, 12:03 AM   #6 (permalink)
woobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond reputewoobiee has a reputation beyond repute
Send a message via AIM to woobiee
def get the OEM alarm, it is a very very good alarm considering its OEM. it consists of motion, and tilt sensors. circlebmw.com has it for $225. Install is very very easy. The hardest part is mounting the siren, and even that is pretty much a piece of cake. You will need to get the alarm activated at a bmw dealer which they usually charge you for. If you are slick enough you can get away with it free.
woobiee - Anamorphic Cycle
woobiee is offline   Reply With Quote
Synthetic Oil and filter CiscoKid 3-Series (E36) 45 04-25-2007 10:50 PM
The American Vs. The German billB 5-Series (E12,E28, E34, E39, E60) 83 10-14-2004 07:09 PM
Upgrading Stock Alarm System Henri Audio and Electronics 4 10-02-2004 06:05 PM
