Alarm on 330Ci convertible - BMW Forum - BimmerWerkz.com
Old 03-04-2004, 04:06 PM   #1 (permalink)
desi330owner is an unknown quantity at this point
I recently bought a used 2001 330Ci manual convertible. It drives great. It has sport and premium package.
I can't figure out the alarm, though. There a red light under the rear view mirror that never flashes. I locked the car with the window rolled down. Then i open the door but the alarm did not go off. The used car dealer told me the car has an alarm. Why doesn't it work? Any thoughts?
desi330owner is offline   Reply With Quote
Old 03-05-2004, 11:49 AM   #2 (permalink)
Is there a way to tell if an alarm is installed at all? Either there is no alarm or it is installed but not working.
Old 03-06-2004, 02:52 AM   #3 (permalink)
playdrv4me is an unknown quantity at this point
All of the cars come with the red light under the mirror, the test you mentioned is the single best way to tell if your car is alarm equipped. Mine even has the electronics housing in the roof for the motion sensor and it still doesnt have the alarm. It seems you do not actually have it (although the manual does detail a disarming option but I doubt this).
<img src='http://members.cox.net/inelson5/330i.jpg' border='0' alt='user posted image' />
<img src='http://members.cox.net/inelson5/wooani.gif' border='0' alt='user posted image' /> The whistles go WOOOO!!! *BUBB RUBB FAN CLUB*
playdrv4me is offline   Reply With Quote
Old 03-06-2004, 11:41 PM   #4 (permalink)
Thanks for the information. I guess i will have to add an aftermarket alarm.
Old 03-07-2004, 01:15 AM   #5 (permalink)
Not necessarily, you CAN still add the BMW factory alarm. Just ask your dealer and they can provide you with the info as the car should be pre-wired for the Alarm, the Cell phone, the CD Changer and other things depending on year.
Old 03-28-2004, 08:03 PM   #6 (permalink)
AutoSolutions is an unknown quantity at this point
Send a message via AIM to AutoSolutions
Look in the trunk lid and if u have a sticker that says is pre wired for alarm is most like it that u do have it, now if is not working you have to take it to the dealer to recode the security system, the factory alarms is good has a tilt sensor for the wheels and inside movement sensor I would add a after market shock sensor at your local specialty stereo alarm shop, dei makes one that works with factory systems.
Good luck
AutoSolutions is offline   Reply With Quote
Old 03-28-2004, 08:28 PM   #7 (permalink)
TECH's Avatar
They can be added easily. I'd go with the BMW alarm. It'll utilize a tilt sensor for the convertible, but not an interior motion sensor, since it is a convertible.
You'll have an alarm siren to install in the firewall behind the microfilter, a tilt sensor in the trunk, and the dealer will have to activate it by programming the car to let it know that the alarm is installed. Simple.
Aftermarket sucks. They always butcher wiring, stuff modules and 30 extra feet of wire under the dashes, and it sucks to have to go behind all that crap to work on the car later. ghead
Old 04-27-2004, 04:06 PM   #8 (permalink)
Thanks for the information. There is a sticker in the trunk that says Wired for Alarm or something to that effect. I'm in favor of a BMW alarm (especially if it is not too expensive compared to aftermarket). I'll go with that.
Thanks.
Old 04-28-2004, 04:53 PM   #9 (permalink)
AZ325Ci is on a distinguished road
i would have the dealer check out to see if you car does have the alarm installed. if there is, then all they need to do is program it to activate.
if it doesn't, then go to http://www.pacificbmw.com or http://www.circlebmw.com and order your alarm kit. you will get the alarm cheaper through them than you would at the dealer.
they are fairly easy to install. just follow the instructions that come with it. you will save $$ on the install and then take it to the dealer and have them activate it. sometimes there will be a small fee or if you know somebody in the service, then you may get this free.
btw, nice car!!
AZ325Ci is offline   Reply With Quote
Old 04-28-2004, 05:26 PM   #10 (permalink)
doughboyea's Avatar
doughboyea is an unknown quantity at this point
Send a message via AIM to doughboyea Send a message via Yahoo to doughboyea
Originally posted by AutoSolutions@Mar 28 2004, 09:43 PM
Look in the trunk lid and if u have a sticker that says is pre wired for alarm is most like it that u do have it....
No Sir, that is not true! I don't mean to sound like an asshole, just I have the same thing in my car but it doesn't have the main alarm components installed, ie. the motion sensor, siren, etc. The only thing that that means is that if you do choose to install one in the future, all the wires are already routed through the car, only thing left is to dish out the $300 +/- for the parts and install it, THEN activate it. Don't be misleaded by that "sticker".
Dough
<img src='http://img.photobucket.com/albums/v298/doughboyea/car3.jpg' border='0' alt='user posted image' />
<span style='color:green'><u>Proud</u> Member of the BMW Community</span>
<span style='color:black'>1999 BMW 328i Jet Black
--Total Dinan Points: 5 --
<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a>Dinan Stage 1 Suspension<a href='http://dinancars.com/SeriesPrint.asp?prod=335' target='_blank'>----</a></span>
<span style='color:black'><a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a>K&amp;N Air Filter<a href='http://www.ajusa.com/cgi-bin/knfilters/start?r=ajusa&ajr_skey=e2398f2ee8c6388757f9e7fb800 a4cb9' target='_blank'> --</a></span>
doughboyea is offline   Reply With Quote
2001 Bmw 330ci Convertible For Sale - $33,000 skratchnsnift Classifieds Sell & Buy 5 04-16-2005 03:04 PM
New 330ci Convertible Owner Spindleton 3-Series (E46, E90) 1 03-13-2005 11:29 AM
2004 330Ci alarm installation instructions Houston330ci 3-Series (E46, E90) 2 08-25-2004 08:04 AM
considering a '01 330ci convertible coos 3-Series (E46, E90) 2 08-06-2004 11:35 AM
