Air Conditioning Smell - BMW Forum - BimmerWerkz.com
Old 05-31-2005, 01:32 PM   #1 (permalink)
jiggs's Avatar
jiggs is an unknown quantity at this point
Hi All,
Everytime I turn off my A/C some really bad smell comes out of the vents for a while. It kinda smells sour and if I turn the A/C back on it will be ok. Any ideas?
Jiggs
jiggs is offline   Reply With Quote
Old 05-31-2005, 02:07 PM   #2 (permalink)
tcarpio is an unknown quantity at this point
I'm also experiencing the same thing.........it happens when the A/c is off and the air recirculation is also off. I haven't had the time to contact the dealership......but any idea to get rid of the smell would help.
tcarpio is offline   Reply With Quote
Old 05-31-2005, 03:19 PM   #3 (permalink)
storme's Avatar
storme is an unknown quantity at this point
here is what i did or an air conditioning specailist will do for a small fortune
i took out my air con filter panel...(panel nder the windscreen wipers)
turned on a/c at lowest temp,,and highest fan setting
sprayed some disinfectant into the aperture and therefore killed all known germs DEAD!!!!!
i used an anti bacterial spray from the supermarket
but the air con specailists willl tell you theres is special.......
also you should use the a/c once a week and full power once a week as well.
visit me at <a href='http://www.storme.co.uk' target='_blank'>www.storme.co.uk</a>
visit me at http://www.janspeed.com
storme is offline   Reply With Quote
Old 05-31-2005, 03:48 PM   #4 (permalink)
jiggs's Avatar
But what's the cause of this?
Old 05-31-2005, 04:34 PM   #5 (permalink)
storme's Avatar
same as in any other air con unit...
bacteria..
have you ever heard of legionaire's disease????
commonly found in office air conditioning units....caused by hot/cold/hot/cold/hot/cold etc etc non cleaning of unit and constant temp change
not saying the cars get the disease but it is bacteria that smells
http://www.buypartsby.co.uk/air-con-cleaner.php
look here
Old 05-31-2005, 05:26 PM   #6 (permalink)
mositure collects in there, the solution described quite radical but perhaps necessary.
i give the ac vents full heat from time to time, to dry everything. also, i hear that recirculation is bad, fresh air good.
the stinking computer also turns on the recirculation on its own, to get the temp lower faster. someone has desribed a way to prevent this, moderators???
Old 06-02-2005, 03:16 PM   #7 (permalink)
djm1k0 is an unknown quantity at this point
Originally posted by jiggs@May 31 2005, 12:32 PM
Hi All,
Jiggs
[snapback]349035[/snapback]
Just replace you cabin filter, it's not that much money to replace and the smell will be gone and you'll have a nice clean filter.
djm1k0 is offline   Reply With Quote
Old 06-02-2005, 04:44 PM   #8 (permalink)
Jrf786 is an unknown quantity at this point
Originally posted by djm1k0+Jun 2 2005, 01:16 PM--><div class='quotetop'>QUOTE(djm1k0 @ Jun 2 2005, 01:16 PM)</div><div class='quotemain'><!--QuoteBegin-jiggs@May 31 2005, 12:32 PM
Hi All,
Jiggs
[snapback]349586[/snapback]
[/b][/quote]
That doesnt work... Anyway, what I did was get some Lysol and spray it into the air intakes for the AC system. It got rid of it for about 2 months, the smell is coming back. So I am gonna try some stronger stuff next time. Probably gonna try walmart or something, I went to a few autoparts stores and none of them had any A/C cleaners or anything. So anyone have any suggestions? The lysol works but it's not strong enough. So anyone have any suggestions to whee I might be able to get one?
Jrf786 is offline   Reply With Quote
Old 06-03-2005, 01:10 AM   #9 (permalink)
storme's Avatar
i just used a anti bacterial kitchen spray,,,in the UK it was a domestos spray,,,but it is harmless to plastics etc and just a germ killer.......
*The E36 Turbo Thread* SpeedInfusion 3-Series (E36) 9 10-16-2005 09:10 PM
Funky Air Conditioning Smell & Dog Smell rsn48 Wash & Detail 3 10-19-2004 05:27 PM
