I got a 2001 325i recently and all seems fine. But tonite when I went to drive it, as soon as I turned the car on the air bag light in the dashboard came on. I have no idea what triggered it. I drove it earlier today without problems. It just stays on for some reason and it wont go away. Has anyone seen this before? What might have caused this and whats the potential problems this raises?
Any fault in the airbag system will cause the light to go on. One very common cause is faulty seat belt receptacles. Others being seat occupancy mats, wiring, module, or the airbags themselves.
Because it is such a huge safety issue I'd recommend getting it to a professional mechanic ASAP.
DT
You can replace the seatbelts yourself IF that is indeed the problem however you will not be able to clear the airbag lamp. You need a diagnostic tool to do that.
DT
[It could be something as simple as the seatbelt recpticle, however it could be more serious and prevent deployment of the airbags if it is more critical.
As everyone else has said you should probably consult your mechanic.
The link below has fault code readers and reset tools if you want to check it yourself.
