Advice? Another coolant system nightmare... - BMW Forum - BimmerWerkz.com
Old 09-10-2008, 11:03 AM   #1 (permalink)
ljk3 is on a distinguished road
Unhappy Advice? Another coolant system nightmare...
2000 323Ci coupe... recently replaced expansion tank due to huge crack. drove car few miles and overheated and coolant spilled out from bottom of car... other than retracing my steps to make sure I installed new expansion tank correctly... any advice on identifying the real problem... i'm handy but certainly no mechanic and would like to try fixing myself before towing to dealership... research suggests thermostat, water pump, head gasket... how do i identify true source of problem?? thanks!
Leon
ljk3 is offline   Reply With Quote
Old 09-10-2008, 11:32 AM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
Remember to bleed the cooling system properly?
Lindsay fan club member.
Old 09-10-2008, 11:36 AM   #3 (permalink)
no but would that cause me to loose so much coolant under the car if i didnt bleed it properly?
would love a phone call if you are open to help me 215-816-0060 Leon
Old 09-10-2008, 12:11 PM   #4 (permalink)
Teh Prof's Avatar
After phone call, to sum up for Leon:
1. fitting on bottom of tank that we talked about
2. bleed your system.
3. Wouldn't be a bad time to replace your water pump and your thermostat if they've never been replaced before. It's good practice for an E46 to replace these every few years.
Old 09-10-2008, 03:30 PM   #5 (permalink)
W00T
Numark318i's Avatar
agreed^^.
Im on my third water pump, expansion tank and thermostat. (140thousand)
Old 09-10-2008, 09:12 PM   #6 (permalink)
acon's Avatar
Car: 2004 325i
acon is an unknown quantity at this point
Question: Other than the car overheating, are there any other signs when the water pump goes out? I ask this because I have an extended warranty which would probably only cover this if the part fails, but I don't want to wait for this to happen and risk losing my engine just to avoid paying this on my own. I think it's better to anticipate these type of things.
My '04 325 has about 78K. I read a buyers guided article for the E46 in Bimmer magazine that the water pump should be changed ever 60K and radiator every 90K as preventive measures. Thx!
acon is offline   Reply With Quote
Old 09-12-2008, 02:27 PM   #7 (permalink)
Car: 2000 bmw 328i
liljavier is on a distinguished road
bleed the system u might have to much air in it causing to expand
liljavier is offline   Reply With Quote
Old 09-13-2008, 09:46 AM   #8 (permalink)
Teh Prof's Avatar
Maybe I'm just paranoid, but I'd say every 35K for the radiator and water pump and thermostat at the same time.
Old 09-13-2008, 10:31 AM   #9 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
As you say it pours out!!!,I would say you have a loose hose clip, split hose or the sensor in the exp tank is not sealing correctly. I would not have thought it would be the rad, as for the pump you would see it leaking and white crystalised water over the belts ( due to antifreeze), best thing to do,take off the the plastc under cover underneath, place a piece of cardboard under and let her just sit there on tick over, give it some revs now a then, keep checking underneath and you should see where its coming from.
Regards,
Marti, U.K.
Rad woes; I'd love some advice on a cooling system upgrade frenchtoast 3-Series (E36) 2 07-01-2007 11:48 PM
Coolant System Leak davlam 3-Series (E36) 3 05-04-2005 12:05 PM
Coolant System Cleaning Kits. kearnyme 3-Series (E36) 3 12-21-2004 10:46 PM
Is the 88-93 750iL a nightmare? supraman215 Bimmer Talk/Motorsports Talk 0 10-23-2003 08:51 AM
