So my main issue is with the AC on my 65k 03' 330Ci. The fan speed displayed on the HVAC matches that of the air coming out of the blower, but the temp does not. All of the HVAC function's work perfectly fine, such as fan speed, defroster, recirculating, etc, But the temperature is the only problem. When i use the heater, it work's fine, but every time i try to lower the temp and use the AC, the result is always the same, and that result is Hot air coming from the top and footwell vent's while cool air comes from the middle. Doesnt matter what setting the HVAC is on, the outcome is always the same for the AC when i need cold air. Could this me a result to the resistor's? I know this is a difficult topic. Ive searched this forum, and have seen some similiar problem's with no answer's...I was happy switching from Audi to BMW, but understand that there will be rpoblem's with the car.
P.S. Disregard my previous post. I did research, and i guess ill get the bushing's, and suspension part's checked out for the metal clunking noise on turn's...Sorry to derail, but my "Low oil pressure" Red light comes on for a brief second when im coming to a stop, and when i accelerate it goes off. I understand by accelerating the oil pickup pump's more oil into the motor, but the dealership assured that the there is no problem with the oil pump, and that the "low oil pressure" red light might be due to old battery, that they said i need to replace...But it makes sense for the light to come on at a stop, and then turn off during acceleration if in fact, the oil pump is going out or bad.
I love this BMW, and have only owned it so far for several hour's, and am planning to keep it. I know these same question's are annoying to red, but i couldn't find the answer's im looking for.
Reason: had to change the title
Yea, and it still act's up. Im going to take it into the Monrovia, CA dealership tomorrow, because it's still under warranty. Look's like im going to have to replace the A-Arms myself because warrantly doesn't cover "wear and tear" part's.
Bob - I am so relieved to see you have the same problem I have. I have a similar problem in the summertime with the temp being cool out of the middle and hot on the feet (in my 2008 328ic). Was your dealership/mechanic able to solve the problem? What was the diagnosis? Thanks for posting!
maybe you don`t have a problem.
Most BMWs have a climatisation feature to offset the face temperature to the foot temperature.
In newer 3series models there is a wheel in in the cockpit near the middle grill to adjust this offset (marked with blue and red).
Red means no offset. Blue means an offset up to 16 degrees Kelvin cooler in the face area (the climate control is adjusting the foot area).
If your model has such an wheel try to adjust the temperature offset to feel comfortable (Other models like E60 have this option below the CCC/CIC menu).
In general loss of cooling in an AC system is most likely caused by loss of refrigerant. This is especially true in older ones. Try having it topped off with a partial can and while adding check the registers to see if an improvement is noted.
In my experience DEV is right......it's a bit confusing at first when you get really hot feet and the rest of the car is cool.
I also think that the temperature sensors, either side of the climate control behind two small grills, sometmes take a while to register overall cabin temperature. I find after I have been driving for a while the cabin temp regulates and cools down a bit.
As DEV says, the middle console vents seem to be independant of the climate control and they do also take a little time to heat up.
DEV, I find that no matter what temp the CC is set that when the middle console is at the Red setting it blows hot air, regardless of temp setting? I think it is independant of everything else......?
actually i work for BMW, ive seen this problem many times, its a problem with the water valve when the middle vent is cold and the defrost and floor vents are hot...
