BMW Forum - BimmerWerkz.com
BMW Forum - BimmerWerkz.com (http://www.bimmerwerkz.com/forum/)
-   3-Series (E46, E90) (http://www.bimmerwerkz.com/forum/3-series-e46-e90/)
-   -   Windshield Wiper Fluid Reservoir (http://www.bimmerwerkz.com/forum/3-series-e46-e90/windshield-wiper-fluid-reservoir-41765.html)
FrankieMyOne 10-15-2005 11:14 AM
I topped of my wiper fluid reservoir before leaving for work yesterday, and all seemed fine when I shut the car off. I come out at the end of the day to start my car up and the wiper fluid low warning light is illuminated. So I thought, this is curious...pop the hood and sure enough she's down to about 25%. And the cap was secure. I have no idea where to start with this one...I'm afraid to take it to the dealer for fear it's a $1,000 job. I'm thinking, a roll of paper towels and a bottle of windex isn't so bad. :D
Let me know if anyone out there has any thoughts on this one.
thanks,
FrankieMyOne
Dirty_Tool 10-15-2005 12:58 PM
sometimes the reservoir itself can develope a leak, also sometimes the pump's internal seals leak. If it stays full to 25% its more likely a leaking pump. Look around the pump for residue or signs of leaking. Pump or reservoir are very easy to replace yourself and save some $$$.
DT
peterkulesza 10-15-2005 06:58 PM
other source of a leak can be the headlights system if you have one. see where the puddle is in the morning.....
FrankieMyOne 10-16-2005 01:43 PM
This was it, the driver's side headlight system is leaking out the fluid...where do I start?
rms 10-17-2005 08:07 AM
leaking washer fluid
I have the same problem on my 2001 325xi. I ordered a new left side spray head for about $40 from the dealer. I pulled to washer head out and found a spray nozzle missing. I'm assuming the missing nozzle in the spray head is actually causing the leak and not the assembly behind the spray head.
peterkulesza 10-17-2005 08:23 AM
this is a very high presssure system, i woudl get a friend and see where exactly this crap is leaking. it may be a simple rubber gasket for 30 cents, but i am afraid that dealer will want the entire assembly replaced... mucho dinero...
FrankieMyOne 11-03-2005 09:13 AM
Can anyone point me to a website that can show me how to investigate taking the headlight apart to get to this hose? I'm thinking about just clamping it shut. If I told you the dealer estimate to fix this you'd laugh :lol: ...They wanted to replace the entire system, to the windshield and both headlights. :eek:
FrankieMyOne 11-03-2005 09:14 AM
How do I just pull the washer head out to see if the nozzle is missing?
FrankieMyOne 01-14-2006 11:20 PM
jvest2000 02-23-2013 09:53 PM
Not sure if you've checked your washer pumps ... I know this is for a different model but on the later model X3's (2006 in my case) the washer pumps start leaking and drain out all the fluid.
Here's a write up and some photos I did on my repair:
BMW X3 Washer Fluid Leak Fix
kerryf 02-24-2013 11:46 AM
Had this problem on my 2005 330 CI. Same fix as above.
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
