| 330i ZHP Idle & Engine Light Does anyone know anything about this? I have a 2004 330iZHP with 75K miles...just recently the engine light came on and it began to idle rough--reduced RPMs and kinda shakes and rattles at the lower RPM's...if I depress the throttle so that the RPM's are at 800+, it feels fine...it runs great otherwise and have no other problems...I took it to the shop and the first time they replaced all the spark plugs and all the coils...reset the engine light of course but it came on the next day--idling was still rough...they checked it again and said its a regulator sensor related to the cam-shaft...said it wasnt a big problem but expensive to repair...I read a bunch of forums and it seams all 330is are plagued by this idling problem...Is this something that I should live with or is it worse than I'm thinkin it is...Also, I just put it on the market 2 weeks prior to all this--is there any reassurance I can give a perspective buyer?
Thanks for your input! |
