330ci Perf Pkg Questions - BMW Forum - BimmerWerkz.com
Old 02-06-2005, 01:06 AM   #1 (permalink)
spotch is an unknown quantity at this point
I did a search but got a few thousand results and after browsing through a few pages none of them seemed to answer my questions so I figured I'd post...
Does anyone know how much weight the performance package adds to the 330ci ? Also, what kind of modifications did they do to the engine and suspension, I read that the suspension was lowered and stiffer but did they include parts from the M3 or just what? Does anyone know anything about this or have a link to a faq about the performance package?
thanks in advance
spotch is offline   Reply With Quote
Old 02-06-2005, 12:21 PM   #2 (permalink)
jefft325i is an unknown quantity at this point
I can't answer your question on weight. In terms of perfornace, the package shaves about a 1/2 second off the 0-60 and 1/4 mile times - this according to magazine tests.....
Performance Package (ZHP) -
Engine mods (new camshafts, re-programmed ECU, & lighter flywheel) for 10HP & 8 ft/lb of torque
Redline increased to 6800 (from 6500).
6 speed short throw shifter (auto available starting in '04, and no SMG with ZHP)
3.07:1 final drive ratio (instead of 2.91:1)
Max speed limiter set to 155 mph (instead of 128)
New M suspension, more "sporty" than standard sport package:
Firmer springs (front +6%, rear +8%)
Firmer shocks (Jounce: front +50%, rear +20%), (Rebound: front +35%, rear -8%)
Larger diameter anti-roll bars: 23.5 mm front (v. 23.0), 18.5 mm rear (v. 18.0)
More rigid forward bushings
Lower ride height by 15 mm (.6 inches) utilizing shorter auxiliary springs
-.5 degrees of camber
BMW M exterior trim elements - front & rear fascia, side sills, & trunk lid spoiler (front and rear fascia, & sidesills often referred to as M tech II body kit)
Unique exterior trim: anthracite (charcoal) headlight & foglight surrounds, high-gloss shadowline (black gloss) trim around windows
Large diameter stainless steel dual exhaust outlets
Extra thick Alcantra steering wheel
Sport Seats - Alcantra & Cloth upholstry to replace leatherette and standard trim (leather still an option)
Choice of "Black Cube" or "Silver Cube" trim (trim is across dash, around shifter)
Anthracite headliner
Red needles on the instrument cluster
Unique 18" Wheels (style 135M), 18x8.0" front, 18x8.5" rear
Wider Tires: 225/40ZR-18 in front and 255/35ZR-18 in the rear.
Article from Car and Driver -
http://www.caranddriver.com/article.asp?se...8&page_number=1
jefft325i is offline   Reply With Quote
Old 02-06-2005, 01:17 PM   #3 (permalink)
Wow thank you very much, thats awesome.
I sat in one w/ the alacantara interior (loved it) and I was wondering if anyone knew if this stuff wore out easily... i mean I dont know how anything so soft and inviting could last for a really long time but I guess anythings possible. Anyone know about the durability of alacantara on things like steeringwheels and shift knobs?
A Couple Questions (thermostat, Brakes On 330ci) jenn330ci 3-Series (E46, E90) 7 01-09-2005 06:37 PM
330ci options list questions light_speed 3-Series (E46, E90) 7 06-02-2004 02:34 PM
330ci interior questions GalvinizedLife 3-Series (E46, E90) 3 01-26-2004 11:57 AM
Questions about a 2001 330ci Dragngt 3-Series (E46, E90) 2 09-25-2003 08:18 AM
