330Ci door rattle - BMW Forum - BimmerWerkz.com
Old 07-12-2004, 07:27 PM   #1 (permalink)
mattchapman is an unknown quantity at this point
Hey
I have a 2001 330Ci which is still under warranty until August . I bought it second hand private. I noticed a subtle rattling when I drive, which is located in the driver side door/window. Is this something I can take into a dealership and have fixed at no cost to me (under warranty)? Anyone else have this problem?
cheers
mattchapman is offline   Reply With Quote
Old 07-12-2004, 10:19 PM   #2 (permalink)
EXtech's Avatar
it should definately be covered. Sounds to me like either a window regulator falling apart, a door that needs adjustment or even just noisy door seals but regardless, take it in.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 07-13-2004, 12:30 AM   #3 (permalink)
JoeSchmo is an unknown quantity at this point
I agree, take your car into the dealership!
Anything repaired for free at the dealer is a lot better than trying to figure out and/or repair the vehicle yourself. If the rattle in the driver's door is truly a window rattle, you might want to inform him/her of existing TSB's involving Aquapel or the BMW Gummifledge.
TSB for Convertibles / Coupes too?
Otherwise, if the dealership can't help, some members have gotten a lot of rattle control out of strips of felt placed between the door panel and the door frame. (This is a door-it-yourself {DIY} project that involves removing the door panel and placing the adhesive felt strips on the door frame, and then replacing the door panel to cushion it again the frame.) You also might want to try spraying the heck out of the door seals with 3M "Wet" Silicone Spray or lubing it with Gummifledge. They might help, but I've only gotten very temporary fix-it time from these measures.
Good luck!
JoeSchmo is offline   Reply With Quote
2001-2006 330ci cchaorule 3-Series (E46, E90) 0 10-20-2005 11:48 PM
330ci bimmer_boy 3-Series (E46, E90) 14 07-11-2004 11:51 PM
remove speed limiter on 330Ci Ohrid 3-Series (E46, E90) 16 07-04-2004 05:44 AM
acceleration of 330Ci Ohrid 3-Series (E46, E90) 11 06-26-2004 02:01 AM
