325i manual vs. automatic RPM - BMW Forum - BimmerWerkz.com
Old 08-28-2004, 05:30 PM   #1 (permalink)
bmwdriver is an unknown quantity at this point
Hi there,
A strange question. I have a '01 Bimmer 325i with stick trans. One of my buddies just bought a '04 325i with auto trans. The interesting finding is, his bimmer hits 80 mph with 3K RPM. Mine hits 80 mph with 3.5K RPM. Is this normal? Is there something to do with the difference in trans.? Thanks.
bmwdriver is offline   Reply With Quote
Old 08-29-2004, 02:46 AM   #2 (permalink)
Ohrid's Avatar
Ohrid is an unknown quantity at this point
Its got to do with the gear ratios and differential. His gearbox has either a taller top gear, or taller final drive ratio.
Ohrid is offline   Reply With Quote
Old 08-29-2004, 11:19 AM   #3 (permalink)
Thanks... but isn't all bimmers (at least E46s) suppose to have the same ratio?
Old 08-29-2004, 12:28 PM   #4 (permalink)
GRD-4-3L is an unknown quantity at this point
No sir, they do not.
Manual and automatic gears definitely have different gear ratios.
Even in manual gear models, 6 gear models have overdrive (less than 1.0 gear output ratio) so it will rev lower at 80 mph.
If you want to know the gear ratios in detail, just look at the specifications given out on bmwusa.com or other BMW corporate sites.
GRD-4-3L is offline   Reply With Quote
Old 08-29-2004, 01:00 PM   #5 (permalink)
Ooommm, very educational. Thanks very much.
changing automatic to manual tranny? headcoat 3-Series (E36) 1 09-16-2005 11:16 PM
The Little Automatic And Manual Button bimmer3214 3-Series (E36) 12 05-11-2005 11:44 PM
Upgrade manual climate to automatic control ! BMW320TD 3-Series (E46, E90) 5 12-05-2004 01:41 AM
Auto - Manual 325i gotKRAUT 3-Series (E21, E30) 18 08-23-2004 01:03 AM
Engine w/ automatic bolt up to a manual? jon84bmw 3-Series (E21, E30) 1 10-20-2003 06:23 AM
