323i 2000 turn signal out - BMW Forum - BimmerWerkz.com
Old 03-31-2004, 10:35 PM   #1 (permalink)
championtycoon is an unknown quantity at this point
I don't have an owners manual for my 323i model year 2000. Does anyone know how to replace the LH front turn signal bulb?
championtycoon is offline   Reply With Quote
Old 03-31-2004, 10:53 PM   #2 (permalink)
gonzo499's Avatar
gonzo499 is an unknown quantity at this point
check out this DIY site, tons of good info, and toward the bottom there are links to do it yourself info on the front corners. it's to change the lens itself, but you'll get the idea.
handy do it yourself linkpage
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1081744190.jpg' border='0' alt='user posted image' />
<span style='color:gray'><span style='font-family:Arial'>2000 323Ci alpine white</span></span>
gonzo499 is offline   Reply With Quote
Old 03-31-2004, 11:23 PM   #3 (permalink)
bearing01 is an unknown quantity at this point
Check the owners manual in your glove compartment. It tells & shows you how to do it. You open the hood and stick a phillips screw driver down into a hole above the signal light. Unscrew the screw nearly all the way. The signal light (lens) should easily slide out. Turn the base of the bulb socket (with cable attached) to remove the light (socket) from the lens. Turn the light bulb to remove it from the socket. The light is a bayonette type of bulb ..... a non-threaded base with two lugs sticking out from the sides. Replace with a standard 21W bulb... I think BMW spec's a Sylvania bulb... but any bulb in this wattage range (and same size) should do. I suggest going with a lower wattage bulb if you deviate from 21W.
bearing01 is offline   Reply With Quote
Old 04-01-2004, 08:13 AM   #4 (permalink)
exjarhead328's Avatar
exjarhead328 is an unknown quantity at this point
Welcome tycoon
I just put clear front corners on my 2000 328 and it couldn't have been easier.Open the hood, insert a screw driver (I think flathead is best) into the oblong hole above the light assembly and depress the locking clip,while at the same time nudging the assembly forward, it should slide out enough so you can pull it out. The locking clip is the flat area you see just below the sort of verticle tab you see immediately below the hole. Unplug the wire, twist the socket, and replace the bulb. To replace the lens simply align the long tabs with the guides and gently push until it seats.
SEMPER FI 2/3 Comm
Founder of the Four Pedal Club
2000 328
exjarhead328 is offline   Reply With Quote
Old 04-01-2004, 10:00 AM   #5 (permalink)
Graphic Designer's Avatar
Graphic Designer is an unknown quantity at this point
Send a message via AIM to Graphic Designer
install will probably take 1 minute. very easy. just follow what these guys said.
o/t-exjarhead328, you have any pics?
garpihc dseigenr
(sp)?
Graphic Designer is offline   Reply With Quote
Old 04-01-2004, 11:36 AM   #6 (permalink)
Mach 5's Avatar
Mach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond reputeMach 5 has a reputation beyond repute
Going to a lower wattage bulb will set the dash warning light off indicating a fault in the system. Make sure you get the same wattage bulb it does make a differance.
Ben
&quot;It's not because I'm an aggressive driver, it's because I'm an idiot&quot; actual quote from my wife.
Mach 5 is offline   Reply With Quote
Turn Signal Problem, stuck on, not blinking. jek1955 3-Series (E36) 2 10-27-2005 06:48 AM
Turn Signal Issues Help warell 3-Series (E46, E90) 4 01-20-2005 02:57 PM
1984 528e Turn Signal Questions. rock_martyr 5-Series (E12,E28, E34, E39, E60) 1 11-09-2004 11:47 PM
97 328i Turn Signal Relay dhruvm 3-Series (E36) 0 09-02-2003 04:18 PM
