318iS Airbag light comes on and off when i have a passenger? - BMW Forum - BimmerWerkz.com
Old 11-15-2009, 11:42 AM   #1 (permalink)
richardrjs81 is on a distinguished road
Hello all hope you can help, i have looked on here but cant find a problem the same.
I have a 2003 318i sport touring, when its just me in the car all is fine but when i have a passenger the airbag light sometimes comes on but will go off and come on when it feels like it.
Any ideas, Many thanks
Rich
richardrjs81 is offline   Reply With Quote
Old 11-15-2009, 11:55 PM   #2 (permalink)
Car: 1997 E39 540i
harryinsaudi is on a distinguished road
maybe a loose/shorting connector under the seat for either the occupancy sensor or the seat belt tensioning device.... You got anything trapped under the seat?
harryinsaudi is offline   Reply With Quote
Old 11-18-2009, 06:47 AM   #3 (permalink)
Car: 2002 325I
jcharles07 is on a distinguished road
There are 3 items that could be your culprit, Occupancy sensor $23.00 on ebay, the seat belt buckle maybe $76.00 and the most terrible on is the mat sensor,not too easy to get it out, the dearler will charge more then $300.00 to replace it or look for some treads on how to replace it if all else fail...since it is intermittent you know is a short somewhere base on what you wrote, weight onthe pass seat might bite some wire and causing a short...
jcharles07 is offline   Reply With Quote
Old 11-19-2009, 08:08 AM   #4 (permalink)
I would think it was the occupant sensor first and for most. I had this issue on another one of my cars and that was the issue. I never fixed it because I never have passengers in that car.
FCP Groton
877-634-0063 | info@fcpgroton.com
FCP Euro - European Car Parts Specialists
FCP Import - Import Replacement Car Parts
FCPGroton is offline   Reply With Quote
Old 11-20-2009, 03:16 AM   #5 (permalink)
Thanks all, will take the seat out and have a look. If i unplug the seat to remove it and plug it back in will the light stay on?
Cheers
Rich
Old 11-20-2009, 09:34 AM   #6 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Disconnect the battery before you pull the seat out........if your radio needs a code make sure you have in case its required on reconnection.
Old 08-16-2010, 09:36 AM   #7 (permalink)
bw46508 is on a distinguished road
Smile Passenger Occupancy Sensor
I had a similar problem in that my airbag light came on for no reason. Turned out it was my Passenger Seat Occupancy Sensor. This is a mat embedded in the seat and if it goes bad, then the airbag light will come on and all airbags are disabled (potentially). I got mine fixed by substituting this sensor with a bypass unit which simulates a passenger all the time. Check out the website:
Home
bw46508 is offline   Reply With Quote
Old 09-03-2010, 05:56 PM   #8 (permalink)
E46 Airbag light
Here is a link to a module sold on ebay
BMW E46 E39 E38 E36 Z3 Airbag Sensor Bypass Unit on eBay (end time 01-Oct-10 13:57:22 BST)
Airbag light, passenger seat occupancy sensor Da Prophecy 3-Series (E36) 33 12-27-2010 07:01 PM
airbag light....... dudehog 3-Series (E36) 2 01-10-2009 10:34 AM
HELP Airbag Light 737flyer 3-Series (E46, E90) 1 09-04-2006 12:22 AM
Airbag Light hardboiled2 3-Series (E36) 3 01-19-2005 03:39 PM
Airbag Deactivated with Passenger Miami545 5-Series (E12,E28, E34, E39, E60) 5 06-21-2004 08:15 PM
