| 2002 325 xi not charging properly I am looking for some help diaging the charging system on my wifes 02 325. I am a ford tech, but seems you need a bmw diag computer to do much on this
car. I am guessing the alternator is cotrolled by the engine controll computer
if I unhook the two wire connector the voltage increases, I guessing it full fields? If this is true I will load the system with the connector unhooked and check the amperage output which I suspect is inadequet. Any input would be appreciated. Thanks Paul |
