1st gear popped out - BMW Forum - BimmerWerkz.com
Old 12-19-2003, 01:55 AM   #1 (permalink)
mikefliggity is an unknown quantity at this point
This happened about 3-4 times this month. When I put it in 1st gear and proceed to go, the tranny does a mild grinding noise and then pops out of gear. Could this be because I'm not putting it in gear all the way or is there anything else wrong with it? TIA
mikefliggity is offline   Reply With Quote
Old 12-19-2003, 02:19 AM   #2 (permalink)
GreenDragon's Avatar
GreenDragon is an unknown quantity at this point
Has it been cold? I have the same issue soetimes, usually in third thogh. From what I can tell it's because I'm releasing the clutch before the gear is fully engaged.
<span style='color:green'>Nobody likes you.</span><img src='http://www.bmw-forums.com/forum/html/emoticons/ph34r.gif' border='0' alt='user posted image' />
<span style='color:green'>Are you experienced, little girl? I want to know what goes on in your little girl world.</span>
<span style='color:green'>I'm the man! I'm bad, I'm so bad I should be in detention. I'm the man!!!</span>
GreenDragon is offline   Reply With Quote
Old 12-19-2003, 02:41 AM   #3 (permalink)
EXtech's Avatar
how does the clutch feel? Where does it release Does it release at the floor, half way or almost all the way up? Sounds like you've either got a clutch issue or a synchro issue.
STETT Performance -
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
EXtech is offline   Reply With Quote
Old 12-19-2003, 02:59 AM   #4 (permalink)
Usually when it's cold. It happens as soon as I release the clutch (at the floor). The clutch feels good, it's brand new.
Old 12-19-2003, 03:05 AM   #5 (permalink)
EXtech's Avatar
Something sure isn't right then. It's possible there is a synchro problem. In fact, there was a bulletin on your complaint at one time. Hey, didn't you just have a motor put in?
STETT Performance -
Everything BMW
Plano, TX 75074
469-767-3309
Old 12-19-2003, 05:46 AM   #6 (permalink)
Yes, I did. I'm going to take it to the dealer and see what they say. Thanks.
Clutch Chatter (grabbing) In First Gear 318is Mario Milewski 3-Series (E36) 1 02-22-2005 12:39 PM
Gear Popping rick316i 3-Series (E36) 2 08-17-2004 02:37 PM
SMG questions... chuckie789 3-Series (E46, E90) 7 08-06-2004 10:55 AM
